Last time I ran my car at the 1/8th mile track, it acted weird. I made one good run with no problems. On my next run, the car ran fine up until about 60+ mph and it sputtered a little and cut out. When I was back in the staging lanes for my next run, I turned the car off. It wouldn't start up after that...not immediately anyway. Eventually I got it to fire. On the next run, the car went down the track fine, but after I let off at the end of the track the car died. Again, it had a hell of a time starting. After it was running I drove it home fine with no other problems. I checked the codes and I had a MAF code (P0121 I believe). The car's had an o2 sensor code since I bought it...needs tuned out.
The only other time it's ever had any rough idle or trouble starting is after I fuel up. But after a few tries it's fine and will drive normal. Also, it's never had an EVAP code since I bought it...which, to my understanding, is associated with fuel.
The car doesn't have a MAF screen either... Ideally I'd like to get a new MAF and put a tb screen back in the car. Any other guesses or suggestions?
TIA
