carb cleaner works well, it lowers the engine idle when you've found the spot.
Ok I will give it a try and post back. We did remove the egr tube apon removal of the lim. Is there a better way to seal that better if it is leaking? Sorry for the questions. haha stupid car!
Little update worked on the car for a little while. Found the vac hose that runs around to evap canister was slit open. replaced that line. There is stll a hissing sound in the rear after i replaced it. I going out tomorrow to buy some more vac lines and see what happens and replace the vac lines back there.
sweet glad to see your finding them. copper rtv works well on the egr if thats leaking
Ok got all my vac lines squared, also found one of the tees had a hairline crack in it. vac is at 19 and at decel it goes to about 25. But now i have a new problem. The oil cap on the front valve cover whistles really loud after about 5 mins of running. When removing there is a lot of vacuum and the noise goes away. I put the oil cap back on and the whistling sound comes back. Do you guys Have any idea what might be wrong.
your PCV is blocked. change the PCV valve.
Thanks guys for all your help. When I replaced the TB gasket on ther side of the spacer i have. I installed it backwards. So it was blocking the pcv port. What a dope I am. haha I hope i didnt ruin anything by having it that way.
