Thread: Whistling sound coming out of valve cover oil cap.
Results 1 to 8 of 8
  1. #1 Whistling sound coming out of valve cover oil cap.
    Apr 2009
    methuen
    I re did all the vac lines and tees in my recent post i had made, because I had a bad vac leak. So what happens now is when the car is running for more than 5 mins a loud whistling sound is coming from the oil fill cap, I removed the oil cap and the noise went away. I put my hand over the hole and there is a lot of suction. What the heck would cause this? TIA
    1.9 Rockers- 42.5 injectors- 3.4" mps- Wizaired 104s- 180*- PRJ 10mm wires- SD headers 3" DP- Hp tuner- Dynotech stage 2- 3.29s 1'' chain
  2. #2 Re: Whistling sound coming out of valve cover oil cap.
    May 2008
    staten island,NY
    that thrasher tb spacer is blocking the pcv. put a breather on instead of the oil fill cap
  3. #3 Re: Whistling sound coming out of valve cover oil cap.
    Apr 2009
    methuen
    I did replace the tb gasket yesterday. Is there a way i put it on backwards. Im gonna check tonight.
  4. #4 Re: Whistling sound coming out of valve cover oil cap.
    GTX Level Member Rather B Blown's Avatar
    Dec 2008
    London, Ontario
    Quote Originally Posted by QwikGT View Post
    this...its crankcase pressure put a breather on problem solved it has nothing to do with your tb gasket
    Quote Originally Posted by Reptile
    It sounds like you accidentally stuffed a midget in the downpipe, and he's hammering out an SOS to get out.
  5. #5 Re: Whistling sound coming out of valve cover oil cap.
    take the throttle body spacer off and tap your throttle body or blower case instead. this will solve your problem without creating another one with a breather.
  6. #6 Re: Whistling sound coming out of valve cover oil cap.
    Apr 2009
    methuen
    Haha it was the TB gasket. I put it in backwards on the other side of the spacer facing the SC inlet for some reason. Turned it around problem gone. I hope i didnt ruin anything with this stupid misshap. Sorry to post it twice. Thanks again for the fast replies.
  7. #7 Re: Whistling sound coming out of valve cover oil cap.
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    you didnt do any damage. Glad you got it fixed
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  8. #8 Re: Whistling sound coming out of valve cover oil cap.
    Apr 2009
    methuen
    Ha ok. Thanks man.
  1. Clunking sound coming from driverside wheel well
    By 2000SILVERSE3800 in forum Brakes/Suspension/Chassis
    Last Post: 10-05-2010, 08:01 AM
  2. Weird sound coming from belts
    By crbquist in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-09-2010, 10:48 PM
  3. Ping sound coming from Front end...
    By andremike in forum Brakes/Suspension/Chassis
    Last Post: 06-08-2010, 02:19 PM
  4. paper flapping sound coming from the rear manifold
    By gpgt2002 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-03-2010, 12:35 AM
  5. Valve Cover
    By justaV6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-25-2008, 09:15 PM
