Thread: supporting mods for a 3.4 s/c pulley
Results 1 to 20 of 27
  1. #1 supporting mods for a 3.4 s/c pulley
    Apr 2008
    Chillin at the Beach , VA
    I am asking a question for a friend. He has a stock GTP and wants to run a 3.4" pulley. What exact mods would he need to support this. I just want to make sure I am telling him the right stuff. Cold air intake, catback exhaust, PCM, colder plugs and thermostat. Do I have it right or am I missing anything? Don't want to see him end up with alot of KR. Tryin g to remember everything I did. It's been awhile.
  2. #2 Re: supporting mods for a 3.4 s/c pulley
    Barksdale AFB, LA
    Down pipe.
    2009 Subaru Impreza WRX STI
  3. #3 Re: supporting mods for a 3.4 s/c pulley
    GTP Level Member JoshMcMadMac's Avatar
    Waynesboro, PA
    The cat-back is not necessary...the exhaust bottle-neck in north of that. U-Bend delete and down-pipe are a good start. That with the PCM, intake, thermostat, and plugs that you mentioned should make it safe.
    2000 NavyBlueMetallic GTP Coupe
    HPTuners / Intercooler / Devil's Own Meth / 1.8 SLP Rockers / 3.1-3.3" / 180° / TB Shield / FWI / PLOG / Jimmy-C Downpipe / U-Bend Delete / Mark VIII Fan / Alt. rewire / FP rewire / F-Body Brakes / Buick Strut Braces / SLP Tips / 20% Tint
  4. #4 Re: supporting mods for a 3.4 s/c pulley
    intake, 3" downpipe, u-bend delete, 180* thermo, colder plugs, and a lot of luck.
    even with my mods (but running untuned) im getting around 4* of knock sometimes. scan, scan, scan.
  5. #5 Re: supporting mods for a 3.4 s/c pulley
    GT Level Member Going Too Phast's Avatar
    Not the almighty 3.4 pulley. Only run as small a pulley as you can safely. A lot of people struggle to run a 3.4. To be safe, this is what I'd suggest:
    #1 Maintenance! (fuel filter, ignition, etc.) Make sure that thing runs perfect before modding.
    Downpipe
    PCM (seems like people with ZZP PCMs have more KR issues, but I may be imagining things...)
    Intake
    180* tstat
    Autolite 104 plugs
    Plog
    Rockers
    ...and scan, scan, scan. If you get KR, go to a larger pulley size unless you want to dump more money into it for mods. If there are plans for 12 second 1/4 times in the future, and you have the money, you may be better off with headers.
    The old recipe of downpipe, intake, and a PCM hasn't worked in 99% of the cases I've seen for a 3.4 to run KR free.
    .: 1998 GTP : 3.5 : PT : 1.9s : Intake : DP : Plog : 180* : 605s : UD WPP : STBs : 12" Brakes :.
  6. #6 Re: supporting mods for a 3.4 s/c pulley
    GrandPrix Junkie FastKatt's Avatar
    Feb 2008
    Rkrd, IL
    Scanner
    /thread
    Going Too Phast just about said it all...
    Plog = waste of money IMHO, mod bug will take you to the headers b4 you're said and done
    Don't get rockers if you plan on a CAM in the future, or you're wasting $$$
    Scanner, Headers w/Downpipe, Intake, 180* Tstat, Cooler plugs (1 heat range), Premium fuel (93 Octane), Custom Tune > Box Tune
    No trees were destroyed for this message.
    However, a great number of pixels were extremely inconvenienced.
    2004 Grand Prix Comp-G GTP Mod List - MySpace
  7. #7 Re: supporting mods for a 3.4 s/c pulley
    NE Ohio
    3.4 sucks, i hate mine, and its a press on so im stuck with it. when i have more money im moving up to a mps 3.8/3.6/3.4.
    i still hvae 6 degrees of (untuned, biggest problem) knock with all my supporting stuff.
  8. #8 Re: supporting mods for a 3.4 s/c pulley
    Lenexa, KS
    Make sure he scans first. On 1.8rr, plog, 3 in DP, rear ported mani, 180 t stat, autolite 104's I run a 3.3 with no kr. (plog started leaking at the crossover and is getting blips because of fueling issues) But I also have an hptuners so I can tune the fueling and timing.
  9. #9 Re: supporting mods for a 3.4 s/c pulley
    Apr 2008
    Thanks for everyones input. I'll pass it on to him and hopefully he'll understand that he can't just trow somwthing like that on without support of other mods.
  10. #10 Re: supporting mods for a 3.4 s/c pulley
    Feb 2008
    Rkrd, IL
    Why doesn't he join the site himself?
  11. #11 Re: supporting mods for a 3.4 s/c pulley
    Apr 2008
    Quote Originally Posted by FastKatt View Post
    I told him about the site. He is new to cardomain and the 3800 world. Waiting to hear back from him to see what he's going to do. Told him this was the place to be. You can lead a horse to water, but you can't make him drink.
  12. #12 Re: supporting mods for a 3.4 s/c pulley
    Huntington, WV
    I had plans for a 3.4 pulley but maybe I should start with a 3.5? I was going to with the modular setup so it wouldn't be hard to switch back and forth.
    I am doing pacesetter coated headers and a cai of some sort first. Could I run a 3.5 with no problems on stock tune with a 180 stat and colder plugs?
    1995 Trans AM 72k miles, 6 speed and all stock.
  13. #13 Re: supporting mods for a 3.4 s/c pulley
    GXP Level Member ryangtp89's Avatar
    Maine
    Quote Originally Posted by AR15 guy View Post
    you gotta upgrade your pcm, i have a zzp 1.0 pcm, but i been hearing alot of bad things about their pcm's l8tly, but who knows, if i where you i would go with overkillmotorsports
    SLP headers, Wizaird cai, zzp1.0pcm ,slp powerflo catback, 3.4mps, NGK TR55's, 180*, zzp stage 1 hv tb,tb spacer, tb heatshield, Triple Edge Performance High performance Tranny, flipped motor mounts, spring blockers, prj 10.4mm wires, Sloted rotors & Ceramic brake pads,Alternator Voltage Booster. zzp 1.9 rockers & 105# springs
  14. #14 Re: supporting mods for a 3.4 s/c pulley
    Huntington, WV
    I have a guy locally that can and has tuned GTP's. I will be taking it to him when I do any kind of serious mod.
  15. #15 Re: supporting mods for a 3.4 s/c pulley
    Apr 2008
    It's good to have someone that can do that.
  16. #16 Re: supporting mods for a 3.4 s/c pulley
    Huntington, WV
    That being said should I start off with a 3.5 or go straight to a 3.4?
  17. #17 Re: supporting mods for a 3.4 s/c pulley
    Bastard Reptile's Avatar
    Kansas City, MO
    I'd say a ported blower couldn't hurt.
  18. #18 Re: supporting mods for a 3.4 s/c pulley
    TDCRacing
    Guest
    Talk to reptile about that.....He does awesome work. Hopefully i will be posting up some pics of my blower that brian did.
    go ahead and get it polished while ur at it(also done by brian)...I did and trust me i am not lookin back
  19. #19 Re: supporting mods for a 3.4 s/c pulley
    Huntington, WV
    I would get mine ported but I can't afford any down time. Which is one reason I was looking at ZZP. But I have heard a lot of bad stuff about zzp lately.
  20. #20 Re: supporting mods for a 3.4 s/c pulley
    Kansas City, MO
    No downtime....I have them in stock to ship out whenever need be.
  1. 3.5 Pulley WITH supporting mods
    By JCG's-GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-03-2008, 11:41 AM
  2. Rockers and Supporting
    By silvermistGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-28-2008, 04:03 AM
  3. Best supporting mod evar.
    Last Post: 01-24-2008, 05:20 PM
