Thread: GTP Shutting off
Results 1 to 7 of 7
  1. #1 GTP Shutting off
    Conway, SC
    Ive got a 99 gtp. it starts up fine . i run it about 5 miles and it just shuts off. it will crank but not start.if i let it sit and cool down it will start again. any ideas would be great . my car is sitting in a parking lot right now. had it happen one time in my camaro and it ended up being the icm. thank s for any input
  2. #2 Re: GTP Shutting off
    GTX Level Member Freebeer187's Avatar
    Bartlett, IL
    Does it over heat?
    Check coolant level and radiator hoses.
    We could use a little more information
    How To: E-Brake Pwn
    2001 GTP. D/S Rotors * Custom Intake * DHP PCM *
    Looking For - 3" in DP with Cat. PM me if selling
  3. #3 Re: GTP Shutting off
    Conway, SC
    nope doesnt overheat all fluids are good
  4. #4 Re: GTP Shutting off
    Hoffman/Schaumburg, IL
    Any Check engine Light? and sputtering, or does it just shut off, any other lights(ABS, TRAC OFF, anything like that)
  5. #5 Re: GTP Shutting off
    Huntington, WV
    Sounds like the ignition module may be bad. I have seen a lot do that. I believe the ignition module is underneath the coils on these cars.
    1995 Trans AM 72k miles, 6 speed and all stock.
  6. #6 Re: GTP Shutting off
    Conway, SC
    well i got it fixed. i unpluged the mass air flow sensor and it started right up , as soon as i would plug it back in it would stall. went and got one , no problem. thanks for all your help guys. i never would have thought a mass air sensor would shut a car off .
  7. #7 Re: GTP Shutting off
    Bartlett, IL
    wow... Good to hear man!!
    How To: E-Brake Pwn
