Thread: Boost help
Results 1 to 8 of 8
  1. #1 Boost help
    SE Level Member ElAlacran2010's Avatar
    Dec 2010
    El Paso, Texas
    i have a 2001 gtp. i"ve noticed on alot of videos of stock gtps running that the boos meter is full at WOT. mine boosts one square less at WOT. Is that normal or is there a problem?
  2. #2 Re: Boost help
    Minnesota
    Not normal. Check the bbv? sometimes it get stuck and will cause that problem
    Open cone, SSAC headers, cat delete, 8.5 MSD wires, 3.4 zzp mps, 180*, 104's, ported blower, DHP canned tune, 19" XXR 962s, DNA springs.
  3. #3 Re: Boost help
    GT Level Member Mitchstrp's Avatar
    Missouri
    also, could be a vacuum leak. Under you supercharger snout, there is a vacuum T and it holds two lines. one goes to the fuel pressure regulator (on your fuel rails) and one goes to your MAP sensor (behind the blower) if it has a leak or is cracked then they need to be replaced. Check these things and it may solve your problem.
    1.8 RR's, Speed daddy headers, 180 stat, Open Cone, GBP tune, 3.5 pulley, and ported blower.
  4. #4 Re: Boost help
    Dec 2010
    El Paso, Texas
    Cool ill check the vacuum lines. What is the bpv? Also I was about to change a worn supercharger coupler. Could that be a problem too?
  5. #5 Re: Boost help
    Dec 2010
    El Paso, Texas
    I mean bbv... Replyin on a blackberry is tough.
  6. #6 Re: Boost help
    SE Level Member DukesGTP's Avatar
    Boardman, Ohio
    My car did the exact same thing for about a year and then about 3 weeks ago my supercharger went to total **** and i had to replace it so it might a good idea to try the coupler but when changing the coupler be careful not to rip the supercharger gasket because if u do then u have to take off the supercharger and do what i had to do and it was a pain
  7. #7 Re: Boost help
    Dec 2010
    El Paso, Texas
    I found the vacuum leak. My bro... Also my mechanic said he had made the the hole to correct for too much pressure in the vacuum lines. He says without the intentional leak my check engine light will come on saying there's a problem with my egr. The comlete vacuum system has been replaced. Along with the egr and maf. He says he doesn't know the problem. But for now I have full boost and I'm saving gas again..... Oh and yea the coupler is gettin replaced this weekend. Hopefully everything goes smoothly
  8. #8 Re: Boost help
    Missouri
    nice well glad you got it figured out, vac leaks suck!
  1. low boost on gtp
    By black98gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-31-2010, 09:22 PM
  2. Why is my boost gauge only reading vacuum and no boost?
    By gtp02 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-21-2010, 02:26 PM
  3. dic boost gauge only shows half boost
    By SilvaMan61 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-10-2010, 07:40 PM
  4. Boost
    By Will5600 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-04-2009, 01:14 PM
