Thread: Need Some Advice please.. I;ve run out of ideas..
Results 1 to 8 of 8
  1. #1 Need Some Advice please.. I;ve run out of ideas..
    SE Level Member rlvis361's Avatar
    Phoenix, Az
    So first i emptied the radiator cause i was running only water and it was getting really cold here so i wanted to add antifreeze... maybe a stupid idea but i did it anyway... after that was done i notice i had a really bad water leak so i figured out tht the water pump was going out so i replaced it last night... heres my problem... when i put the supercharger belt back on i guess i was off by one rib so it jumped off while i was parking at my apt. so i fixed the belt no big deal.. when i started the car after that it had a really bad miss and the check engine light was on... so i limped up to the autozone to get the codes checked... i got a cylinder 5 missfire and fuel injector failure code.. so i replaced the wire and plug in cylinder 5 ... when tht was done the problem seemed to be fxed but once i got home again which was about 1/4 mile away... when i restarted the car to leave the same problem was back again... SO NOW IM OUT OF IDEAS..any info would be greatly appreciated... sorry its so long but i didnt want to leave anything out...
  2. #2 Re: Need Some Advice please.. I;ve run out of ideas..
    St. Louis
    I would check all the wiring to the coils and see if it was damaged when the belt jumped off. Also, check the post on the coil and see if it's clean.
    Jay
  3. #3 Re: Need Some Advice please.. I;ve run out of ideas..
    GT Level Member donmega's Avatar
    St louis, mo
    ur belt coming off is NOT GOOD. may want to check ur timing. dont know if the belt came off but it can throw off you timing....
    "well we can spend 1000s throwing parts in it and hope that fixes the problem or we can diag it correctly and change the .50 cent fuse...lets ask the owner what he wants to do" --Walt R.--
  4. #4 Re: Need Some Advice please.. I;ve run out of ideas..
    Florida
    The supercharger belt comming off isnt going to mess with the timing.
    You may have damaged a coil pack, or the ICM with the belt comming off. Check every single wire going into the ICM for damage, and make sure that the coil pack is good.
    You can swap out 2 coil packs and see if the misfire follows, if it does, its the coil.
  5. #5 Re: Need Some Advice please.. I;ve run out of ideas..
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    running normal and not distilled water isnt a wise choice(even running straight distilled isnt good). You have a number 5 injector code. Instead of replacing the plug wires and plugs id start at the injector and see if the plugs loose. swap the injector see if the mis moves.
    And I lol'd about the blower belt and timing
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  6. #6 Re: Need Some Advice please.. I;ve run out of ideas..
    St louis, mo
    wasnt paying attention to which belt der! Yea y change the plug and wire if the code is for an injector? check injector
  7. #7 Re: Need Some Advice please.. I;ve run out of ideas..
    SE Level Member 1998DaytonaPaceCar's Avatar
    Dec 2010
    Lawton / Fort Sill, OK
    +1 check injector
    1998 Daytona Pace Car #1371 of 1500
    Mods: Pacesetter headers, 3.4" S/C pulley, 180ยบ t-stat, K&N FIPK Intake kit, Cross drilled rotors, 18" rims, DHP PCM, Custom exhaust (Cherry Bomb glasspack acting as resonator, 2X Corsa sport mufflers from my old 06 GTO R.I.P.)
  8. #8 Re: Need Some Advice please.. I;ve run out of ideas..
    Phoenix, Az
    Thanx for all the answers.. i took the car to the shop cause i dont have time to troubleshoot its my only means of transportation right now.. the mechanic told me that the injector was in fact bad getting it replaced now... they also found another coolant leak.. i think he said a coolant bypass or something... THIS CAR HAS SOO MANY LEAKS! but this should be the last only ive fixed the rest... THANKS AGAIN...
  1. Need some ideas
    By tyv193 in forum Off Topic Discussion
    Last Post: 11-22-2010, 05:00 PM
  2. Any ideas?
    By IBurnCamaros in forum Visual/Body Modifications
    Last Post: 10-03-2010, 04:47 PM
  3. tattoo ideas for my cast! post your ideas!
    By putskijr in forum Off Topic Discussion
    Last Post: 07-11-2010, 04:53 PM
  4. ideas
    By Will5600 in forum General Tech Discussion
    Last Post: 03-18-2010, 07:27 AM
  5. Any Advice/Ideas??
    By Grandprixse97 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-07-2009, 11:08 AM
