Thread: throtle body?
Results 1 to 10 of 10
  1. #1 throtle body?
    GT Level Member Louie3's Avatar
    Laguna Vista
    So whats an improvement over the stock one? any other GM TB interchangable?
    ZZP PCM, Wbody PCM, Custom PCM ( the best ), Headers, 3" exhaust, 3.4" pulley, ZZP 10.3 Wires, AL 104's, 160 tstat, 1.9 Rockers, Custom huge cone intake. Gunna push this GTP to the limit.
  2. #2 Re: throtle body?
    Charles City, IA
    There are no upgrades for the 04+ tb.
    SMGPFC Two Nipple General
  3. #3 Re: throtle body?
    Your upgrades = elsewhere...you you can man up and be the first to figure out how to put a LS2/LS7 TB on your car...probably total overkill at this point...but if the pins are the same, and the bolt pattern can be adapted...I don't see why not.
  4. #4 Re: throtle body?
    Laguna Vista
    Really? Boo I wanted some more umph from my car. My friend has a ls2 throttle body that I would've used. Guess I'm going to play around with it
  5. #5 Re: throtle body?
    Get Methanol Injection.
  6. #6 Re: throtle body?
    Laguna Vista
    I've read up a little on meth but haven't really gotten into it. I just want to start making some stupid power in the GTP people already get freaked out I want them to see 12s or less at the track from a newer GP
  7. #7 Re: throtle body?
    Intercooler or Cam then...that'll make it happen with a tiny ass pulley.
  8. #8 Re: throtle body?
    GT Level Member rmcardle3's Avatar
    Houston, TX
    I am putting together a LS1 Throttle body kit and I need a MAF upgrade. The preffered methode seems to be LQ4 MAF. Has anyone here done any research on use of LS1 MAF 3.5 (98 Z28)?
    Just wondering:
    Has anyone had any luck or tried using an LS1 MAF (it's 3.5") out of a 1998 Z28? I found one for $20.00 but I won't waste the money if someone here already has.
    2000 GRAND PRIX GTP (Sedan)
    MICHELIN Pilot® Sport A/S Plus 245/50 ZR16 97W M+S
    Cone Intake, SD Headers
  9. #9 Re: throtle body?
    Houston, TX
    I may have answered my own question.
  10. #10 Re: throtle body?
    I hope you planning a cam and tiny ass pulley along with that LS1...because it sure won't help you at your current mod level.
  1. yay...its such a w-body :)
    By BoostJunki3 in forum General Tech Discussion
    Last Post: 10-22-2009, 03:59 PM
  2. W body
    By cowmilker08 in forum General Tech Discussion
    Last Post: 04-08-2009, 07:05 PM
  3. Major loss to the G-body/W-body community
    By Sabrewings in forum Off Topic Discussion
    Last Post: 05-21-2008, 03:47 PM
