Thread: WOW! Got the KR now.
Page 1 of 3 123 LastLast
Results 1 to 20 of 42
  1. #1 WOW! Got the KR now.
    Slower, Lower Delaware
    I have been trying to see what KR I have. Tried the Droid with Torque ap, didn't show anything. I bought an aeroforce gauge. Didn't show anything. I've been showing 11.2 boost on both gauges. This morning, 34 degrees outside, on the aeroforce I hit 13 lbs of boost and as much as 4.5 to 5.0 in KR. I'll try it again when it warms up outside. Opinions?
  2. #2 Re: WOW! Got the KR now.
    GT Level Member SlowRR's Avatar
    Brookfield, IL
    There's a app on droid to see if you have kr? How much is safe? I hopefully get my aeroforce today and kinda scared to see what mine is hitting.
  3. #3 Re: WOW! Got the KR now.
    KR season is coming boys....
    You should have a plog at LEAST on that car if you wanna run that 3.6 in the winter.
  4. #4 Re: WOW! Got the KR now.
    I have a plog. Trying to figure where I want to go next.
  5. #5 Re: WOW! Got the KR now.
    Sell the DP/PLOG setup...get some Speed Daddy's. I don't see an intake on your list...granted...that won't help fight KR much...so...I'd try the headers. Being as cheap as they are now you can almost break even selling a DP/PLOG and buying those headers.
  6. #6 Re: WOW! Got the KR now.
    I've thought about headers but never really cared for them on a daily driver.
  7. #7 Re: WOW! Got the KR now.
    Nov 2009
    Grand haven
    Buy the headers.
  8. #8 Re: WOW! Got the KR now.
    MA
    the headers will help. i dd'd them on my last gp and i will be on this one as well.
    whats with the "kr season"? is kr more common in winter?
    SMGPFC Member #9
  9. #9 Re: WOW! Got the KR now.
    knock is more common in winter because colder air temperatures increase boost and timing.
  10. #10 Re: WOW! Got the KR now.
    Which means RAAAPE.
  11. #11 Re: WOW! Got the KR now.
    Which means RAAAPE.
    What gets RAAAPED?
  12. #12 Re: WOW! Got the KR now.
    Your face
  13. #13 Re: WOW! Got the KR now.
    your face
    :d
    are you really old enought to drive?
  14. #14 Re: WOW! Got the KR now.
    Jersey
    Which means RAAAPE.
    Quote Originally Posted by Sudden View Post
    What gets RAAAPED?
    Your face
    he's 13 1/2, we ride the school bus together
    you need a tune, there is a parameter table in my DHP called air temp vs timing table (or something like that) this table comes in handy when weather changes.
    16' wrx sti- stock
  15. #15 Re: WOW! Got the KR now.
    MA
    Your face
    lol YO FACE
    hmm never really thought about it like that, thanks for bringing it up ill keep it in mind when i drop the pulley. evan though by then ill have an aeroforce setup.
    SMGPFC Member #9
  16. #16 Re: WOW! Got the KR now.
    SE Level Member Whiplash Performance's Avatar
    Hillsborough, NJ
    0 Degrees kr is optimal as long as the car was tuned for maximum hp without knock.
    maximum timing without knock does not always yield max horsepower.
    5 degrees is ok as long as it starts dropping off as rpms go up. Any knock will start decreasing engine life, since knock is the piston skirt hitting the cylinder walls.
    During the winter you should see less knock because the heat causes denotation. If you look at stock IAT spark advance correction table you'll see the hotter it is the more timing taken out. As seen here:
    Most tuners will tune this table to subtract spark advance as temperature, volume efficacy(including boost) or rpm increases.
    So if tuned correctly, you shouldn't see any knock at any temperature.
    Whiplash Intense Performance Hillsborough, NJ
    Performance Parts & accessories| Powder Coating | Engineering
    Intensewhiplash.com
  17. #17 Re: WOW! Got the KR now.
    utah
    im tuned on a 3.3. no knock ever. winter in utah or racing in summer in cali. get urself a tune. its always worth it in the long run.
  18. #18 Re: WOW! Got the KR now.
    It shouldnt drop off as the RPM goes up....
    Very few peoples cars are tuned for multiple air temps...
  19. #19 Re: WOW! Got the KR now.
    my car knocked like a mofo in the winter, even tuned on low timing.
  20. #20 Re: WOW! Got the KR now.
    how much boost did you see though?
    I'm up about 1.5 PSI already just going from 70 to 35* F.
wow
