Thread: P0717
Results 1 to 7 of 7
  1. #1 P0717
    GT Level Member deadsnake's Avatar
    Round lake, IL
    Hello good peeps....need some help, my tranny has been shifting funny...... lost 3-4 MPG and about 5 LBS of boost.....i got the check engine code p0717....changed the vehicle speed sensor and still no go...what do i do??
  2. #2 Re: P0717
    Round lake, IL
    99 gtp
  3. #3 Re: P0717
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    Input/Turbine Speed Sensor "A" Circuit No Signal. Sounds like a bad sensor or harness. I think you have to crack into the trans for this also. TSB Number: 020730022A
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  4. #4 Re: P0717
    Round lake, IL
    SO its the ISS not the VSS?
  5. #5 Re: P0717
    Round lake, IL
    Where is it even located?
  6. #6 Re: P0717
    Round lake, IL
    anyone?
  7. #7 Re: P0717
    GT Level Member torq455's Avatar
    Dec 2008
    Alabama
    Inside the tranny.
    2002 GTP: K&N, 3.2 pulley, flipped mounts. ZZP SS headers, 180 stat, NGK TR6's, MSD wires, Reptile ported TB, ported S/C, ported LIM, Intense Stage II heads with larger Manley severe duty SS valves, Yella Terra 1.9 full roller rockers, LS6 springs, Racetronix fuel pump re-wire, Oil pressure "kit", JMB FWI. Mustang dynoed at 240 WHP, 272 WTQ.
  1. p0717, p0716, What fixes this
    By Jambat1 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-08-2010, 10:57 AM
