Thread: help with sc
Results 1 to 5 of 5
  1. #1 help with sc
    Donating Users crock's Avatar
    Traverse City, Michigan
    Ok so i was coming home from the movies with my girlfriend the other day and i was on 470 when this charger was riding my butt when i was already going 70. so i picked it up alittle bit. i put the boost half way in and the car was jerking. like the supercharger couldnt do it. the engine was shaking the whole car. it has never done that before. Could the supercharger be going bad? or does it need more oil? motor mount? i just want my baby fixed
  2. #2 Re: help with sc
  3. #3 Re: help with sc
    I'll be it has nothing to do with motor mounts.
    This is likely ignition related. Check/replace plugs, wires and coils.
  4. #4 Re: help with sc
    SE Level Member bstuby's Avatar
    charleston, IL
    Mine did that. When i would get over 3000 rpm it would shake, shudder, and fall all over its self then ses light would start flashing. Turned out i had a crack in the #4 plug. Easy fix
  5. #5 Re: help with sc
    I live here. TLSheff's Avatar
    Quote Originally Posted by bstuby View Post
    Agreed... same thing on my bonnie... freaked the hell out of me
    simple fix, just check all the plugs. BTW A fine crack on a clean plug is VERY hard to find, but can cause this problem. Take some dark grease or dirt, something dirty that will fill into a crack on the plug and rub around the ceramic insulation. Itll make finding a cracked plug easier. If they are all good, you may consider changing wires, or testing the coil packs
    good luck
