Thread: CAI causing wierd noise
Results 1 to 13 of 13
  1. #1 CAI causing wierd noise
    GT Level Member Xorbex's Avatar
    Canada
    Put a Cai on this summer and now the car is making some sort of gargling noise. Hard to explain and I have no audio for it. It definately is affected by the rpms. It usually only happens @ 1/4 throttle if i go harder u cant hear it (drowned out by s/c noise) Not sure whats going on, I know when you put a cone filter on u can hear the valves more but i didnt think it would make a chug/gargle noise its not quite a tick either. 2005 Comp G 70000km on her. Oh and the oil gets pretty dark other than that no other symptoms. I am going to seafoam soon. Was wondering if one of my lifters is gone or going. Any suggestions?
    RIP August 2015 - (2005 Comp G // Custom HAI / S1X Cam / 105 Crow Springs / Mild Ported heads / 3.4 Pulley / SD Headers / Dynomax Catback / Overkill Tune / Comp cams pushrods / LS7 Lifters //)
  2. #2 Re: CAI causing wierd noise
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    Normal, Its the IAC valve.
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  3. #3 Re: CAI causing wierd noise
    Sounds like a shovel being dragged across concrete.
    Normal.
  4. #4 Re: CAI causing wierd noise
    Topeka, KS
    It's normal. You just hear it more with a CAI setup vs the stock setup.
  5. #5 Re: CAI causing wierd noise
    Jan 2009
    Michigan
    I just hate that it sounds like somethings F'd up. I can't count how many times I've been asked what's wrong with my car or when someone starts trying to tell me what it could be lol. Can't wait to put my northstar on
  6. #6 Re: CAI causing wierd noise
    N* = lamesauce.
    Got the mods for it?
  7. #7 Re: CAI causing wierd noise
    Canada
    Thats good news thx for the replys, now what could be causing the dirty oil... I change it every 5000km or less and use synthetic and the car has somewhat low mileage only 70000 km = 43000 miles. What type of seamfoam should I use there are a few kinds I can get my hands on.
  8. #8 Re: CAI causing wierd noise
    Jan 2009
    Michigan
    N* = lamesauce.
    Probly not enough for full potential but I'm putting it on with my genv.
  9. #9 Re: CAI causing wierd noise
    You don't need a bigger TB as in the LS1/N* until your cammed or shooting sub 3.2" pulleys
  10. #10 Re: CAI causing wierd noise
    am i the only guy that likes that noise?
    my car needs that much air, no big deal.
  11. #11 Re: CAI causing wierd noise
    Charles City, IA
    I like the noise. You realize your car is drive buy wire right? and the n* tb is not.
    SMGPFC Two Nipple General
  12. #12 Re: CAI causing wierd noise
    And you HAVE to use your stock TB...there is no upgrade unless you can figure out a way to match the pins from a larger bore DBW TB such as a LS2/LS7
  13. #13 Re: CAI causing wierd noise
    Apparently 04+ = no IAC....
  1. wierd noise after acclerating
    By mk frilla in forum General Tech Discussion
    Last Post: 09-26-2010, 01:34 AM
  2. Replies: 8
    Last Post: 03-11-2010, 07:59 AM
  3. What's causing this?
    By BwolfGT in forum General Tech Discussion
    Last Post: 10-02-2009, 04:57 PM
  4. What is causing my MAF to go out?
    By MartinTD in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-30-2009, 04:33 PM
  5. Why is my MAP sensor causing my car not to start?
    By 1998gpgt in forum General Tech Discussion
    Last Post: 05-11-2008, 06:20 PM
