Thread: timing belt
Results 1 to 11 of 11
  1. #1 timing belt
    SE Level Member DunriteDiesel's Avatar
    May 2008
    Pennsylvania
    hello everyone. just taking a poll and trying to pick your brains. 1998 GTP, cars been great since ive had it. Besides maintence the only thing thats went bad on my car is 1 waterpump, 2 alternators, and the powersteering pump. the car just crossed the 194000 mark and ive been struggling with a misfire thing for a while, but ive got it nailed down to the timing belt. i talked to a mechanic and he said not to replace it because it might cause other skeletons in the closeet to appear. what is ya'lls opinion. i love the car and definatly dont want to put her down or have to replace the whole motor. i trust the mechanic but it just seems wierd that it cant be replaced with no bad side affects. what ya think?
  2. #2 Re: timing belt
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    You dont have a timing belt. Its a chain
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  3. #3 Re: timing belt
    Charles City, IA
    replacing the timing chain will not make anything else break. It could be worn out causing the timing to be off, I would go ahead and replace it.
    SMGPFC Two Nipple General
  4. #4 Re: timing belt
    May 2008
    Pennsylvania
    i meant chain, sorry head
  5. #5 Re: timing belt
    Feb 2009
    flintnasty MI
    misfire? 3800's are known for spark plug wire and ignition coil issues... I am willing to bet one of those is causing the issue.
    BTW, there is nothing "scary" about 200k on a 3800... Hell alot of us dont start modding till 180k miles.
  6. #6 Re: timing belt
    IMO your mechanic isn't a 3800 expert and probably shouldn't be trusted on this one.
    A single cylinder misfire is not a timing chain related issue. If that were the case, a simple CASE Learn would help the pcm relearn tdc and you'd be set. Your misfire is probably a plug, wire or coil. I have actually found a bad ICM to cause a coil to not fire for one cylinder. A weak coil can cause this type of thing as well.
    What spark plugs are you running? Age?
    What plug wires are you running? age?
    What coils are you running?
  7. #7 Re: timing belt
    check yo balancer.
    Mine caused awesome misfire issues because it was separating.
    Why is it rubber?
  8. #8 Re: timing belt
    Feb 2009
    flintnasty MI
    check yo balancer.
    Why is it rubber?
    its call a harmonic dampner for a reason.
  9. #9 Re: timing belt
    SBC = solid metal IIRC.
    Progress is make it out of a material that works better but only lasts 10 years?
  10. #10 Re: timing belt
    you missed the point: cost.
  11. #11 Re: timing belt
  1. 1994 pontiac grand prix se timing belt questions
    By 1994grandprixse in forum 3.4L V6 (LQ1) DOHC
    Last Post: 09-02-2010, 10:04 PM
  2. Timing belt swap
    By Ryan D. in forum 3.4L V6 (LQ1) DOHC
    Last Post: 03-03-2010, 04:54 PM
  3. N/A Cam timing
    By skidoojames151 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-14-2009, 01:12 AM
  4. Timing Belt
    By Doerr in forum 3.4L V6 (LQ1) DOHC
    Last Post: 12-05-2009, 11:01 AM
  5. Got another timing???
    By GTP4 in forum PCM Tuning
    Last Post: 11-15-2008, 07:38 PM
