Thread: Hey guys i need some help...
Results 1 to 20 of 20
  1. #1 Hey guys i need some help...
    GT Level Member tyv193's Avatar
    Jul 2010
    Central Ny
    For the past few weeks ive noticed my boost is getting lower and lower. I dont know what is happening. Now its down to 2 bars of boost on full throttle. Anyone have this happen? It seems like my gas mileage is going down too.. Please if anyone has had this problem i need some help
  2. #2 Re: Hey guys i need some help...
    do you have a scan gauge? does your car seem to idle normal?
  3. #3 Re: Hey guys i need some help...
    Jul 2010
    Central Ny
    What do you mean by scan gauge? And yea it idles normal. When its cold around 1000 rpm and warm about 8000
  4. #4 Re: Hey guys i need some help...
    if you have to ask then you dont have one... lol
    do you have any mods?
  5. #5 Re: Hey guys i need some help...
    Jul 2010
    Central Ny
    My dad works for a dealer and has a scan tool that checks engine codes and everything. The person who had the car before me has a msd ignition in it and thats all i believe.
  6. #6 Re: Hey guys i need some help...
    and no codes are coming up?
  7. #7 Re: Hey guys i need some help...
    Jul 2010
    Central Ny
    No, no codes. At first i thought it was because i had a new catalytic converter installed but it kept getting less and less boost.
  8. #8 Re: Hey guys i need some help...
    does it feel slower?
  9. #9 Re: Hey guys i need some help...
    Jul 2010
    Central Ny
    I just noticed tonight accelerated hard and only like two bars of boost showed up. I havnt had time to really see if its any slower. Didnt seem a ton slower.
  10. #10 Re: Hey guys i need some help...
    GT Level Member Mitchstrp's Avatar
    Missouri
    my buddy actually had the same problem tonight, he just tightened/replaced all his t fittings under his supercharger and it fixed the problem.
  11. #11 Re: Hey guys i need some help...
    Charles City, IA
    You have a vacuum leak find it and fix it.
    SMGPFC Two Nipple General
  12. #12 Re: Hey guys i need some help...
    Problem could be a vacuum leak, however it's more likely the boost control soleniod is going bad. While doubtful the actuator could have an issue as well.
  13. #13 Re: Hey guys i need some help...
    Jul 2010
    Central Ny
    How would i go about finding the vacuum leak? If i push down on one of the belts should there be any play? It still sounds like the supercharger is running
  14. #14 Re: Hey guys i need some help...
    Jul 2010
    Central Ny
    could the vacuum leak cause anything with gas mileage?
  15. #15 Re: Hey guys i need some help...
    Very much so.
    Probably the rubber "T" fittings and lines around the fuel rail and blower and the one from the TB to the EVAP solinoid. Most common problem with these cars besides LIM gaskets...dry rot.
  16. #16 Re: Hey guys i need some help...
    Jul 2010
    Central Ny
    So most likely a vacuum leak? Are they a pain to fix?
  17. #17 Re: Hey guys i need some help...
    All you have to do is replace the rubber "T" fittings and plastic lines around the blower and fuel rail like I stated. You can buy the entire set from a GM dealer for less than $30.
  18. #18 Re: Hey guys i need some help...
    Jul 2010
    Central Ny
    Ok thanks. Is it going to hurt the car if i drive it like this ? Is it actually affecting my boost or just the gauge?
  19. #19 Re: Hey guys i need some help...
    its making your car run lean, which youll blow it up if you keep rocking on it.
  20. #20 Re: Hey guys i need some help...
    Largo, Florida, United States
    Obvious Vac leak.
    just as general maintance replace your "T" Fittings and al your Vac hoses
    any GM dealer has the Whole Vac line set for pretty cheap or you can go to an autoparts store and get rubber line and run those.
  1. What do you guys think
    By Beanz in forum Tires & Wheels
    Last Post: 04-05-2010, 03:43 PM
  2. Any RC car guys here??
    By Trannyman95 in forum Off Topic Discussion
    Last Post: 01-19-2009, 11:44 PM
  3. Hey guys!
    By zoomtm in forum Introductions/Noob Questions
    Last Post: 01-12-2009, 08:04 PM
  4. Hey guys
    By 1998xGTP in forum Introductions/Noob Questions
    Last Post: 12-24-2008, 10:24 AM
  5. attn: guys who are car salesman or guys who know them
    By shaferz in forum Off Topic Discussion
    Last Post: 03-25-2008, 05:05 PM
