Thread: Major oil leak!
Results 1 to 20 of 26
  1. #1 Major oil leak!
    utah
    So after changing out my oil pan gasket, and doing the timing chain, everything ran excellent for a little while, but low and behold I look under the car and there is some nice oil leaking...I checked the oil pan and there was hardly any oil on it, but where the crank is there was a good amount...im thinking its the crank seal, but it could be the timing cover gasket...when I put on the metal gasket I just put it on bare without any rtv...in the manuals it didnt say to add any so i just let it be. Should I have put anything on other than the gasket?
  2. #2 Re: Major oil leak!
    Charles City, IA
    Probably could have used some rtv on it. Crank seal could also be leaking. Time to take it back apart, the joys of working on cars.
    SMGPFC Two Nipple General
  3. #3 Re: Major oil leak!
    utah
    what type of rtv do you recommend for the gasket and seal?
  4. #4 Re: Major oil leak!
    Charles City, IA
    ultra black.
  5. #5 Re: Major oil leak!
    utah
    thanks man
  6. #6 Re: Major oil leak!
    you didnt use any RTV in the front cover area? youre for sure supposed to put some where the front cover and oil pan meet or there will be a leak.
  7. #7 Re: Major oil leak!
    utah
    Ahh...that could be it! I would have thought they would have put a note in the manual or on the gasket instructions about that. With the LIM gasket they included the black rtv and told you exactly where it goes. Also with the oil pan they say not to use rtv specifically...Ill get the rtv on the gasket! Should i pull the seal out and coat the inside of the seal with rtv or anything? I just want to make sure this is done right this time!
  8. #8 Re: Major oil leak!
    Denver
    No - don't put any RTV on the inside of the seal.
  9. #9 Re: Major oil leak!
    utah
    RTV on the pan gasket? The gasket I had has the pre-done gasket material on the gasket...On the instructions it says specifically not to use RTV. I changed it once before about 5 years ago and it never leaked.
  10. #10 Re: Major oil leak!
    youre also supposed to put RTV all over the pan gasket.
  11. #11 Re: Major oil leak!
    if you got a GM gasket with no gasket sealer on it then you need to use RTV or it'll leak.
  12. #12 Re: Major oil leak!
    utah
    So i found the problem...The crankshaft seal that I just bought is totally torn to shreads! So im guessing the way I installed it is totally wrong...Can you put up a brief write up on the correct way to install the seal? I remember looking on the forum a while back and didnt find anything...
  13. #13 Re: Major oil leak!
    I've seen it installed with a big up socket.
    Didn't leak, but the car did die four hours later from something unrelated.
  14. #14 Re: Major oil leak!
    Charles City, IA
    Yup a big socket, or just tap it in with a rubber mallet working your way around.
  15. #15 Re: Major oil leak!
    utah
    actually another thought too...when pulling the harmonic balancer off, it just came off without any give...i didnt even need the puller...so im thinking the balancer wasnt in all the way (even though the bolt was on tight). When reinstalling the balancer should I give it a few blows with a socket and hammer to get it on farther on to the crank?
  16. #16 Re: Major oil leak!
    utah
    Alright...Attempt 2...Still leaking like a mother right at the seal...I can see it pouring down right into the cradle...its also looking like the balancer is moving back and forth quite a bit, but I got it torqued down like a mother...help?
  17. #17 Re: Major oil leak!
    GT Level Member Vegas~Blown's Avatar
    Aug 2008
    vegas
    how are you installing the seal? I lucked out once beating one in but the second time I wasn't so lucky. I ended up having a friend make me a tool that uses the crank bolt to draw the seal in --- works great.
    Also, hows the snout on your balancer? if there's a groove on it it'll tear the seal in no time flat.
  18. #18 Re: Major oil leak!
    Portland Oregon
    Your balancer should not be able to move at all. You're doing something wrong. The balancer bolt is also torque to yield. Are you torqueing it to the proper spec and rotating it the proper degree? It requires replacement every time you have it off
  19. #19 Re: Major oil leak!
    Portland Oregon
    Also, bio is incorrect about the pan gasket. The gm pan gasket has viton rubber embedded in it all around, the only part that requires rtv is on the corner where the block, pan, and front cover all meet. I've installed several like this with no leaks at all.
  20. #20 Re: Major oil leak!
    utah
    I looked at the hb and there is some minor scoring on it...I will get a new hb and bolt (gotta wait until monday). also do you guys have the seal number? i read all the numbers on the one from the felpro box and no one seems to be able to find it...I just dont feel like paying for my third timing cover gasket kit when i just need the one seal.
  1. Major Problems - Need help, please
    By dellfire in forum Off Topic Discussion
    Last Post: 11-04-2009, 09:37 PM
  2. Help Major problem
    By Krazicustom in forum 3.1L V6 (LHO/LG8)
    Last Post: 05-08-2009, 09:16 AM
  3. Will I get major knock?
    By SlowM90 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-10-2009, 03:13 PM
  4. major own-age!
    By gtpinsc in forum Off Topic Discussion
    Last Post: 10-31-2008, 10:38 PM
  5. Major unbeatable KR
    By Sabrewings in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-17-2008, 06:14 PM
