Thread: phil's build thread... back from the dead yet again
Page 12 of 14 FirstFirst ... 21011121314 LastLast
Results 221 to 240 of 264
  1. #221 Re: phil's build thread... unforseen issues
    Donating Users Taz Magister's Avatar
    Dec 2010
    Ohio
    Re wire all 3 of them ? Unplug the maf you tried that I don't even run a rear o2 on mine so re wire that one last if at all the maf and the front o2 shouldn't take long to do maybe first unplug the maf and see what happens.
  2. #222 Re: phil's build thread... unforseen issues
    Troy OH
    i unplugged the maf... i guess i'll throw the one from before the build back on. the O2 is new, and i don't have a rear one either. i'm leaning towards a bad maf harness/connector/something, i've gone through like 4 of them now. O2's won't cause serious misfires, it'll just richen up fuel trims
  3. #223 Re: phil's build thread... unforseen issues
    Dec 2010
    Ohio
    So the maf wad causing it?
  4. #224 Re: phil's build thread... unforseen issues
    Troy OH
    idk... i just remembered that i've gotten all those codes before and they technically never got erased... i'm gonna have to check when the code was set, because maf readings were fine on the aeroforce
  5. #225 Re: phil's build thread... unforseen issues
    Troy OH
    f*cking radiator broke. seriously? it's been driven once in 6 months.
    anyways, misfires on 1,2, and 6. firing order is 165432. so that explains the ****ty idle, only half of the engine works. maf and oxygen sensor codes didn't come back after i cleared them, must have just been stored in the pcm.
  6. #226 Re: phil's build thread... unforseen issues
    I have a rad if your interested
  7. #227 Re: phil's build thread... unforseen issues
    Dec 2010
    Ohio
    Check your plugs ?
  8. #228 Re: phil's build thread... unforseen issues
    Troy OH
    plugs are new... i have an ignition module laying around, and i think some spare coils... when i get a chance to work on it, that's probably what's getting switched out. i wonder if it has anything to do with the evap code
  9. #229 Re: phil's build thread... unforseen issues
    Minnesota
    Oh man I feel bad for you. I alwasy run into a bunch of little problems when doing projects, no where near the magnatude of this but, I feel your pain. I hope you get it figured out soon. And when you do, you and taz need to race and have someone film it!!
    Open cone, SSAC headers, cat delete, 8.5 MSD wires, 3.4 zzp mps, 180*, 104's, ported blower, DHP canned tune, 19" XXR 962s, DNA springs.
  10. #230 Re: phil's build thread... unforseen issues
    Dec 2010
    Ohio
    It would just be a video of us torque steering into one another and exploding into a massive fireball, Phil you can borrow the scan gauge as long as you need it my car is parked for the most part just don't forget to give it back when your done
  11. #231 Re: phil's build thread... unforseen issues
    Troy OH
    thanks man, i'll remember this. unfortunately the firebird needs tires, a u-joint, and a brake caliper before i can justify throwing anymore money into the grand prix, unless it's the ignition module or coils or something cheap that i have laying around. def no money to tune it. so fingers crossed it's simple
  12. #232 Re: phil's build thread... unforseen issues
    how is your radiator broke?
  13. #233 Re: phil's build thread... unforseen issues
    Troy OH
    it looks like it split where all the metal tubes go into the plastic tank on the driver's side
  14. #234 Re: phil's build thread... unforseen issues
    You want mine? You can just have it I need to clean my garage out.
  15. #235 Re: phil's build thread... unforseen issues
    Troy OH
    that would be sweet man, coldwater is up north somewhere isn't it?
  16. #236 Re: phil's build thread... unforseen issues
    Yeah I work in minster which would be a lot closer to you if you could get it during the day. Coldwater is close to celina if you want to get it later on in the afternoon.
  17. #237 Re: phil's build thread... unforseen issues
    Troy OH
    only problem is i still don't have my license for another month. ****
  18. #238 Re: phil's build thread... back from the dead yet again
    Troy OH
    alright guys, i'm gonna figure this out if it f*cking kills me. it appears that it's not going away, so lets put our collective heads together and get this piece going.
    a short summary:
    GT block, GTP top end, ported everything, 105#s, modded retainers/seals, double roller, AL 104's, stock injectors, not tuned.
    Codes stored: P0300, P1646. P1646 is the bypass solenoid circuit. i don't have the sensor wired in. the vac line running from the map sensor around the engine goes through the bbv and into the T on top of the supercharger. P0300 is, of course, random/multiple cylinder misfire.
    so, why is it missing? every now and then i'll have a dead miss at an engine speed raised above idle, and when it returns to idle, cylinders 1, 2, and 6 are dead. they're all on different coils, on both cylinder banks. map readings were a steady 17-19in Hg at idle. oxygen sensor and maf sensor readings responded to changes in throttle. no knock, but the engine wasn't under load; i never saw any boost either. that's about all i have for diagnosis.
    i emailed intense for a little more background on the camshaft, just to see if it causes a rough idle or would go away with a tune. i would love to be able to do a laundry list of tests for compression, leakdown, fuel injector flow, etc. but i don't have any way to get the tools to my car. so... who has a good spot to start with diagnosis?
  19. #239 Re: phil's build thread... back from the dead yet again
    all the coils die at once? ICM issue or your wiring harness leading up to it has been messed up and is grounding out intermittantly.
    the 'rough idle' is normal, but it shouldnt have a straight dead miss. it should missfire, so the P0300 code is 100% normal.
  20. #240 Re: phil's build thread... back from the dead yet again
    x2.
    I'd start tracing grounds and take your ICM to the local auto parts store and have it checked out.
  1. ZZP XPZ Build
    By bbptech in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-25-2017, 09:40 PM
  2. 280-340 HP build
    By patturlington in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-11-2011, 02:33 AM
  3. New build.
    By TheOtherNick in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-15-2010, 05:44 PM
  4. phil's livid
    By Poil336 in forum The Rant Forum
    Last Post: 08-15-2010, 04:37 AM
  5. The Build...?
    By Thunderturd in forum Off Topic Discussion
    Last Post: 11-04-2009, 07:35 PM
