Thread: Belt tensioner replacement.
Results 1 to 17 of 17
  1. #1 Belt tensioner replacement.
    SE Level Member 59VetteFI's Avatar
    Dorr
    My belt tensioner is getting squeaky on my 04 GTP and I was wondering how big a job it is to replace it. I did some resarch and from the pics it looks like there is more to it than just the pulley and tensioner, there seems to be an aluminum casting with it. Do I have to replace all that? If so is it as big a PITA as it looks? Or can just the tensioner and pulley be replaced
  2. #2 Re: Belt tensioner replacement.
    Wooster, Ohio
    you just need a pulley more then likely, and there normally like $13 and just the one single bolt to replace. If you need the entire tensioner then it will be the whole cast arm, loaded with a spring and i would guess in the 50-65 range
    edit- just take your belt off the pulley, grab it and try to move it up and down and side to side, if you feel any movement in that then the bearings are out and thats your issue
  3. #3 Re: Belt tensioner replacement.
    Apr 2009
    stockton ca
    Its easy to swap out the pullies autozone carries them they ar 16-18 and they are the metal ones not plastic
    If ones out the others are sure to follow
  4. #4 Re: Belt tensioner replacement.
    Dorr
    That's good to know I was hoping I could just do the pulley, but I was doing some searching on line like Rock Auto, etc. and I couldn't find the pulley for sale seperately. I will check auto parts stores tomorrow. Those are reverse threads right?
  5. #5 Re: Belt tensioner replacement.
    Donating Users blowfishRus6's Avatar
    g.a.
    the main belt tensenor is reverse thread, the supercharger belt tensenor is regular thread.
    my lower idler pulley for my supercharger was squeaking, pulled it off and there is a little bushing that fits inbetween the bolt and the bearing on the pulley (it takes up the slack, the bolt is not the same size as the bearing and with out the bushing the pulley can slop around) that bushing was not in right, once i put it back together it stoped squeaking.
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  6. #6 Re: Belt tensioner replacement.
    Dorr
    The one that is squeaking is the one below the alternator. I think that's the main tensenor isn't it? I know that's the one becasue if you spray it with WD-40 it will stop squeaking, but then a day or so later it will be as loud as ever.
  7. #7 Re: Belt tensioner replacement.
    g.a.
    the pulley is like 20 bucks. its the main one for the main belt, well only one.
    its slow.
  8. #8 Re: Belt tensioner replacement.
    Your ClubGP Liason copgtp's Avatar
    Orange County, NY
    It really depends on the "type" of squeaking your getting. Diagnosing a squeaky belt system can be troublesome if you just start replacing items you "think" might be the problem. Do yourself a favor and get a nice long screwdriver, then very carefully, while the car is running, put the screwdriver on the body of the tensioner and put your ear to it. If the squeak is audible from that then you need a new tensioner.
    For all your 3800 needs:
  9. #9 Re: Belt tensioner replacement.
    Dorr
    I will try that, but I know that if I spray silicone spray right on the tensioner pulley it will stop for about a day, then start squeaking again.
  10. #10 Re: Belt tensioner replacement.
    Orange County, NY
    It doesn't hurt to change the pulley don't get me wrong. And as long as you have a good parts shop in your area, I'm sure you can exchange it towards a tensioner replacement if you need to. I had the same problem as you and it turned out to be the tensioner making a "chirping" noise.
  11. #11 Re: Belt tensioner replacement.
    SE Level Member dipset1413's Avatar
    Jun 2010
    Chicago
    im having the same chirping noise im going to change my belt tensioner tomorrow
    im guessing its that when i spray it with wd-40 is stop for a min or two so im going to swap it out
    3.8 supercharged hud screen four monitors crazy system yea its over kill so
  12. #12 Re: Belt tensioner replacement.
    Dorr
    I ended up doing mine, it cured the problem and was fairly easy, straight forward to do.
  13. #13 Re: Belt tensioner replacement.
    Jun 2010
    Chicago
    thanks bro imma do that
  14. #14 Re: Belt tensioner replacement.
    Jun 2010
    Chicago
    i changed the belt tensioner solve that horrible noise problem damn thing cost 105 but i'll pay it to get rid of that noise
  15. #15 Re: Belt tensioner replacement.
    Holy jesus...you got bent over...next time go to a junkyard or visit
    Morad Parts Company - 3800 Motors, Transaxles, & Stock Parts
  16. #16 Re: Belt tensioner replacement.
    GTX Level Member noreasonwhyy's Avatar
    Michigan
    or post a WTB. i have a tensioner pulley that i have no use for.
    97 GT - slow, rusty
    93 CTD - more slow, less rust
  17. #17 Re: Belt tensioner replacement.
    ^^See
  1. Symptoms of a bad belt tensioner
    By valleyd01 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-02-2009, 07:20 PM
  2. belt tensioner
    By shawnz90 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-12-2009, 06:29 PM
  3. Belt Tensioner
    By LANCER in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-12-2009, 09:40 PM
  4. Drive Belt Tensioner Replacement [*]
    By 03GPScottyd in forum How To Write-Ups/Tech Tips
    Last Post: 01-03-2008, 10:54 PM
