Thread: Low boost on a 3.4 setup
Page 3 of 3 FirstFirst 123
Results 41 to 52 of 52
  1. #41 Re: Low boost on a 3.4 setup
    SE Level Member GTP2188's Avatar
    Benton, Arkansas
    I have been talking to ASE GM Master Tech on just answer and here is what he said about the cat.
    You have received an Answer!
    From Paul M ASE Master Tech GMC L1
    Thursday, October 07, 2010 4:53 PM EST
    A clogged cat would decrease vacuum and increase boost
    Paul
  2. #42 Re: Low boost on a 3.4 setup
    yeah, one of the nicks said that.
    now disconnect the lower vacuum line on your BBV and see what happens.
  3. #43 Re: Low boost on a 3.4 setup
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    Bad BBV valve (more then likely), or belt slip or a bag gauge
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  4. #44 Re: Low boost on a 3.4 setup
    plz explain how a restriction in exhaust flow will cause less boost.
    Because it was a joke, job guy.
  5. #45 Re: Low boost on a 3.4 setup
    Benton, Arkansas
    I tested the BBV and it seems to be working. Im about to go get a new belt and try that out
  6. #46 Re: Low boost on a 3.4 setup
    Benton, Arkansas
    Well got it fixed replaced the belt and cleaned the air filter, will be putting the DP in soon!! THanks for the help.
  7. #47 Re: Low boost on a 3.4 setup
    put the 3.8 pulley on....
  8. #48 Re: Low boost on a 3.4 setup
    Benton, Arkansas
    if i put a downpipe in and ubend delete why would i do that
  9. #49 Re: Low boost on a 3.4 setup
    MA
    dont buy a downpipe, just get headers,they are $220 or something crazy low like that.
    evan with a dowinpipe your exhaust isnt flowing as much as it should, youd have to replace the front exhaust manifold as well. this is why the headers are great. front and rear mani, crossover, down pipe, and ubend all taken care of
    SMGPFC Member #9
  10. #50 Re: Low boost on a 3.4 setup
    what is your tune for?
  11. #51 Re: Low boost on a 3.4 setup
    Benton, Arkansas
    the 3.4 setup with the large downpipe and ubend delete
  12. #52 Re: Low boost on a 3.4 setup
    WI
    Oh I'm not? Ok...telling you putting on a stock pulley isn't helping? Telling you you probably need to address your spark plugs because they might be smashed isn't helping? I've toasted plenty of motors jeeves...and if you don't like my comments...tough sh1t? Its the internet...hate me I don't care...but I bet 20 to 1 I'll figure out your problem before you do...could be a clogged converter too...and probably because you still have the ENTIRE stock exhaust...is childish.
    I lol'd.
  1. Why is my boost gauge only reading vacuum and no boost?
    By gtp02 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-21-2010, 02:26 PM
  2. New HID and LED setup.
    By Koniig in forum Visual/Body Modifications
    Last Post: 09-17-2010, 12:16 AM
  3. dic boost gauge only shows half boost
    By SilvaMan61 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-10-2010, 07:40 PM
  4. Setup to go for?
    By Dthreap in forum Turbo
    Last Post: 01-26-2010, 08:50 PM
  5. my old setup
    By whitcomb in forum Audio, Security & Visual Electronics
    Last Post: 12-21-2009, 06:49 PM
