So the other day i had to move my car. Then literally 4 hrs later i left and noticed i had a 8inch by 8inch oil stain on my driveway, in 4 hours!!!. It wasnt there before i moved my car cause i woulda seen it, duh. So i put my car on a lift that my buddy has and i cant find the $%&#* leak. Its wet more-so in the back of the motor, also wet by the oil pressure senor (i think thats it's name). It also looked REALLY wet looking up between the oil and trans pan. Possibly where the leak is, but not sure as of yet. Theres another sensor when i look up and that looked wet too (that being in-between the oil and trans pan.) lol Im losing it over tryin to find this leak. I put oil dye in it so ill let you no bout that, but where do you think its coming from with givin info?!?!?! thanks!!
EDIT: I also cleaned it up with brake cleaner to see if i can tell where its coming from too. Its been 2 days since this oil leak happened and still isn't dripping yet so idk why i had such a big puddle and now nothing. Still letting the dye chill in the oil for another day.
