Can I use a 8 rib supercharger Pulley on my 98 gtp, didn't know if it mattered or not
Yep, I just took off an 8 rib and put another 8 rib back on. As long as your hub is flush with the end of the shaft and you center the belt on the pulley (1 open groove on each side of the belt) then you are good to go
alright thanks
