Thread: Car saying reduced engine power.
Results 1 to 12 of 12
  1. #1 Car saying reduced engine power.
    GT Level Member Louie3's Avatar
    Laguna Vista
    This just happened tonight. I was driving on the bridge and gunned it like I always do at night ,but this time my car said reduced engine power and turned off 10 seconds later. I pulled over trned off the car completely and tried turning it on and nothing, just kept turning over. I stopped for about 2 mins and she started back up with a bad idle and a check engine light. The car drives fine with regular throtle.
    So on the way home I try to see if the problem would spur up again so I let her rip and sputter sputter sputter reduced engine power then loss of power. So I'm like wtf. I get home an notice I am showing no vacume pressure on my vac/boost gauge. I dont have it plugged in to light up yet so I couldnt tell when I was driving.
    I'm going to see what I can do in the day time but would anyone know what it is directly.
    ZZP PCM, Wbody PCM, Custom PCM ( the best ), Headers, 3" exhaust, 3.4" pulley, ZZP 10.3 Wires, AL 104's, 160 tstat, 1.9 Rockers, Custom huge cone intake. Gunna push this GTP to the limit.
  2. #2 Re: Car saying reduced engine power.
    Oct 2008
    Calgary, Alberta
    Step 1: DONT BEAT ON IT
    Step 2: Look for the vacuume leak re vac gauge not working
    Step 3: get the car scanned for engine codes (engine light) if the vac leak is not the only issue
  3. #3 Re: Car saying reduced engine power.
    Portland Oregon
    Usually if it shows reduced engine power one of two things occurs.
    1. You lost your supercharger belt
    2. You have a REALLY bad vacuum leak which would result in rough idle/stalling until you put your foot on the gas and try to move.
  4. #4 Re: Car saying reduced engine power.
    GT Level Member duane9586's Avatar
    Apr 2008
    ny
    Mine did that a while back and it ended up being a wire was grounded. I don't remember what wire it was, might have been the alt wire
    180*, Overkill, K&N, MSD, GEN V, AL 104's,ZZP Shift kit,SD Headers,1.9rr's, 90#,3.2zzp,0KR, 8K HID,Was a Base Model
  5. #5 Re: Car saying reduced engine power.
    Laguna Vista
    Ok so in the morning I did a little looking around and found what it was
    the part that connected the rubber cracked and came off. Hard to belive that little thing can kill my car lol
    I replaced it, drove the car a little bit, romped on it and it was totally fine and the check engine light was gone
  6. #6 Re: Car saying reduced engine power.
    Nov 2012
    canada
    Where did you find the problem? I've scoured up and down mine to no avail. I'm almost certain it's the same issue but I can't find anything similar to your photo..... I suppose I could pay someone to look at it but... you know
  7. #7 Re: Car saying reduced engine power.
    Florida
    Isn't it ****ing great when it's something simple like that??
    Glad to hear it was a quick fix and not a PITA.
  8. #8 Re: Car saying reduced engine power.
    Donating Users
    Indiana
    Wow! I wish I always got that lucky haha
  9. #9 Re: Car saying reduced engine power.
    Jan 2012
    Tennessee
    Thank you Louie. My car did the same thing yesterday and I was at a gas station waiting for a tow truck and i found this forum on my phone. I saw your post with the picture and started looking. It was the same exact issue. I canceled the tow and rigged it back on there to drive to the parts store. Cost $3.54 for the fix. I can't thank you enough.
  10. #10 Re: Car saying reduced engine power.
    get a better vacuum line and it won't just pop off under high load like that.
    GTP Level Member Ultra440's Avatar
    Ohio
    Right under supercharger snout. Follow all your lines.
    2003 Park Avenue Ultra- 15% tint, 12" audiobahns, dynamatted trunk and doors, tinted tails, LEDs all around, HID headlights, f body brakes, sd headers, 3.5 pulley and supporting mods
    http://www.grandprixforums.net/my-03...tml#post824292
  12. #12 Re: Car saying reduced engine power.
    Jun 2013
    Prince Edward Island Canada
    I had this happen to my 2004 grand prix gt and it was as simple as checking the battery posts .. With the style of fitting from the car to the post over time it can become loose and if the connection is loose you will get this message , or your car may not turn over .. Hope this helps someone out there .
  1. Reduced Engine Power/Service Traction Control
    By SteveNMe in forum General Tech Discussion
    Last Post: 08-07-2010, 10:36 AM
  2. Reduced Engine Power???
    By 05gtPEACE in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-29-2010, 06:21 PM
  3. No engine power above 2-3K?
    By scottm in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-01-2009, 02:58 AM
  4. "Reduced Engine Power" message
    By TomDaBomb2u in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-19-2009, 11:00 PM
  5. Reduced Engine Power
    By donpedro_81 in forum General Tech Discussion
    Last Post: 09-22-2008, 07:20 AM
