Thread: engine hesitation/ missfire at wot
Results 1 to 6 of 6
  1. #1 engine hesitation/ missfire at wot
    SE Level Member Hawkman's Avatar
    Jun 2010
    North east, WI
    So i was on why way to wrok and stepped on the gas and all of a sudden i had a hesitation and high kr! i have stock pully btw. it run fine when not in boost but as soon as you bring it to wot it misses and hesitates, any ideas whats going on? i just installed plugs about 3 months ago and wires just yesterday. at work i took a quick look and found a vacume hose cracked and though i had my problem, did a quick wot down the road and all ok! then on the way home same problem! and no hoses bad that i can see! sorry for the long story!
    all stock just as the car was intended!
  2. #2 Re: engine hesitation/ missfire at wot
    GT Level Member t24moore's Avatar
    Feb 2008
    Houston
    Do you have anything to scan with? A bad oxygen sensor can cause these symptoms. When did you last change it?
    Comp Turbo 6765 T4-ST5-A2A IC-Ported Heads-Custom Turbo headers-80 lb inj-F-Body UIM and LIM-AEM WB, TEP trans w 1" chain and Circle D TC, Dual 255s, Bilstien Struts
    WHY IS EVERYONE SO OPPOSED TO DOING A COMPRESSION TEST TO TROUBLESHOOT PROBLEMS?
  3. #3 Re: engine hesitation/ missfire at wot
    GTX Level Member cerick08GP's Avatar
    Just a guess but it sounds like your running lean. I’d start by re checking your wire install, look for stuff you may had disconnected or damaged. Then I’d take some carb cleaner or propane and look for vacuum leaks. Good luck
    Ten years of continuous driving excitement and counting!
    2008GP
    ||HV3 insert||PowerSlot rotors w/Hawks||LED interior||MSD 8.5mm
    2002GP||sold
  4. #4 Re: engine hesitation/ missfire at wot
    Jun 2010
    North east, WI
    no i will have to run to autozone and see if the car stored any codes it doesnt trip any ses lights or anything though so i dont know if im going to get much help from the brain lol. can only try i guess
  5. #5 Re: engine hesitation/ missfire at wot
    Charles City, IA
    Could be a cat starting to clog up.
    SMGPFC Two Nipple General
  6. #6 Re: engine hesitation/ missfire at wot
    Jun 2010
    North east, WI
    well guess im not going to have my gp in the dells have to take another car. have a new cat and headers ,waiting to get put on when i get back.
  1. missfire HELP!!
    By Will5600 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-25-2014, 10:25 PM
  2. missfire on cylnder 1 and 5
    By Rocket468 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-25-2014, 10:15 AM
  3. missfire under boost
    By blowngp3 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-06-2012, 04:33 AM
  4. 04 GTP missfire
    By dlemmen in forum General Tech Discussion
    Last Post: 07-07-2010, 09:29 PM
  5. Engine Hesitation
    By Blowntato in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-28-2009, 06:52 AM
