Thread: Unexplained Oil on Engine
Results 1 to 20 of 20
  1. #1 Unexplained Oil on Engine
    SE Level Member mlasnoski's Avatar
    Jun 2010
    Marquette, Michigan 49855
    Hello Everyone,
    Just wanted to see if anyone could help me solve this.
    I have a 2004 GTP CompG with 100,600 miles on the clock. I have had the LIM gasket and Upper Gasket replaced along with a tranny flush and new filter installed. I have wetness above where the transmission bolts to the engine. It looks to be oil, but I'm confused. All levels are good and everything seems to be fine. I had the valve cover gaskets replaced as well. I don't believe it should be wet. I have attached a photo to show kind of the location of where the said wetness is at. If anyone knows anything that would be greatly appreciated.
    http://i952.photobucket.com/albums/a...925_165943.jpg
    Thanks!
    Mike
  2. #2 Re: Unexplained Oil on Engine
    Jun 2010
    If that top link doesn't work...try this one
    Pictures by lasnoskim - Photobucket
  3. #3 Re: Unexplained Oil on Engine
    Donating Users
    South Deerfield, MA
    Hard to say from that picture, but wetness in that area is usually a lim gasket or could be the thermostat gasket. Clean the area up and then watch it for new wetness before it spreads out. That should help to track it down. Maybe there was a problem with the new lim gasket sealing properly?
    2002 GTP: GMPP Sway Bars, BMR trailing arms, KYB AGX/Vogtlands, 12" brake upgrade
    Modified SSAC headers, K&N Intake, 3.4 MPS, S1X, Gen V, 104's, HPTuned.
  4. #4 Re: Unexplained Oil on Engine
    Get a towel or a tissue and dab some of it up and look at the colour.
  5. #5 Re: Unexplained Oil on Engine
    Jun 2010
    I should mention the gasket was put in 4 months ago. In May, before I bought the car. But yeah I suppose it could be any possibility. If it's the LIM, I will demand the garage that did it to re-do it CORRECTLY. Does that sound fair. It should last longer than 4 months.... I will be sure to call that garage when I found out the issue. Parts of me also doesn't trust the garage anyways. The previous owner took the car there. That wouldn't have been my first stop.
  6. #6 Re: Unexplained Oil on Engine
    Jun 2010
    UPDATE:
    Turns out I have 2 oil leaks. =/ Lower Intake Manifold and the Rear Main Seal. Could I have any worse luck. The estimate was $1200.00 where I live to do both jobs. I'm currently in works with the original garage that did the Intake 4 months ago...it shouldn't already be leaking....ugh I hate crappy mechanics. My current garage was saying something about spacers used in the LIM that some mechanics use and some don't and the mechanic that just replaced this one 4 months ago..didn't use them. It all depends on the mechanic. My current garage said they have better luck using them.
    I'll keep posted, what happens.
  7. #7 Re: Unexplained Oil on Engine
    Charles City, IA
    There are no spacers for the intake.
    SMGPFC Two Nipple General
  8. #8 Re: Unexplained Oil on Engine
    Jun 2010
    yeah, I don't remember what he exactly said. All I heard were $$$$ My dad said not to worry about the Rear Main. My oil level is still full. Will see what this other garage is going to do. Labor rates up here, where I live are $65.00 an hour.
  9. #9 Re: Unexplained Oil on Engine
    I live here. TLSheff's Avatar
    This is a basic breakdown of the 04 GTP engine, the #533 that is right above the block is the seals some mechanics leave out... why i don't know but some don't like them, i guess a "fill with silicone" state of mind takes over and you end up with leaks later that have you coming back for more work... win win for the mechanic, loss loss for you
    Unexplained Oil on Engine Attached Images
    Last edited by TLSheff; 10-01-2010 at 01:58 PM. Reason: Update picture and slight re-write
  10. #10 Re: Unexplained Oil on Engine
    I thought you were supposed to use those then add dabs of black RTV in the corners to make sure it seals properly.
  11. #11 Re: Unexplained Oil on Engine
    you are, but IF you dont, it could leak, and ive heard of some mechanics that just fill in the area of silicone and let it be
    theres alot of shady techs today, everyone looking for the quick buck rather than a good rep and solid work.
  12. #12 Re: Unexplained Oil on Engine
    I dont get it. that parts COMES with the gasket set... I mean there is no excuse for not using them.
  13. #13 Re: Unexplained Oil on Engine
    Charles City, IA
    They are old school guys. All those rubber seal leak on sbc's so you just rtv it. I have never had an issue sealing one on a 3800 tho. Also its easy to see if they are in, the tabs hang off the side.
  14. #14 Re: Unexplained Oil on Engine
    Jun 2010
    Interesting. I really do enjoy learning about out cars, even though its nickel and dime-ing me to no end. Yeah it was those tabs he was talking about above that they left out. GRR. And no call back from the garage that did it 4 months ago. I really hope they will re-do it without a cost to me. It shouldn't start leaking after 4,000 miles that just seems shotty. My Grand Am lasted 2 years before it s**t out again.
    I might just hold off on the RMS. It's only seeping out. My oil level remains full. My dad said to wait until I start to notice it on the dipstick. Is this wise advice or should I bite the bullet and just replaced it all. UGH. Thanks guys for your knowledge. =) I learn from you guys.
  15. #15 Re: Unexplained Oil on Engine
    Topeka, KS
    Quote Originally Posted by mlasnoski View Post
    That's cheap. Most shops around here are $98.00 and I live in NE Kansas.
  16. #16 Re: Unexplained Oil on Engine
    Most shops around here are free...and I live in BFE Missouri
  17. #17 Re: Unexplained Oil on Engine
    GTP Level Member SuperSport's Avatar
    Michigan
    Because the South kicks ass and Im jealous of anyone who lives there.
    Also to the idiot shop mechanics that dont use the included rubber side pieces...thats the dumbest thing I have ever heard of. I could see if it was a seperate part and they didnt order it...
    2001 Grand Prix GT Coupe
    Comp G Wheels - SS Corners - Infinity Sound - Tint - Digital DIC Swap - 893 Fogs
  18. #18 Re: Unexplained Oil on Engine
    Donating Users iroc2's Avatar
    Jul 2010
    Lansing IL
    UPDATE:
    ive herd its a bad idea to do a trans flush. fluid changes are fine just not flushes. i have almost he same problem. mines leaking at the front main seal and like 1 or 2 other places.
    SMGPFC # 008 -White 1995 Grand Prix SE: tinted tails, Flowmaster 40 Series mufflers with resonating tips. much more to come eventually
    Quote Originally Posted by Xorbex View Post
    I almost beat the man but murphy showed up.
  19. #19 Re: Unexplained Oil on Engine
    Charles City, IA
    as long as your transmission is not shot to begin with a flush will be fine.
  20. #20 Re: Unexplained Oil on Engine
    Jun 2010
    I don't believe it was a flush, I think they just drained the old stuff and put in a new filter and filled it up. They checked for particulates or metal shinny pieces and they didn't find anything.
    Update: The garage that repaired the LIM before I bought the car is going to fix it for free. He doesn't believe its the whole LIM leaking, but rather a corner area, where the motor mount is on the right side. He's going to take it apart tomorrow and see what he sees. Which just tells you why he should have used those tabs. I really hope he's just not going to band-aid the situation. It's not seeping a lot, but just the idea. I'll keep posted what the guy finds. I still don't like the dude, he seems sketch and he's the owner. UGH
  1. Spartans Engine Swap (Engine Damage Pics on Front Page!)
    Last Post: 05-05-2010, 12:50 AM
  2. Starting engine on engine stand?
    By bbptech in forum Off Topic Discussion
    Last Post: 01-13-2010, 01:23 PM
