do any l67s only utilize one coolant elbow like my 97 l36 does? if so what years?
depends on the tensioner bracket thats on there i guess.
I always thought they all had two.
I can tell you 99+ will for sure have two regardless of which engine it was.
top swap
Pick up Dorman 47065 for the two elbows and you'll either use one elbow and the large o-ring off the second or both elbows. Etiher way..you'll want to spend the $4 to get both.![]()
read the top swap thread.
dude, that's not what i'm asking. since all other motors use 2 coolant elbows, i'm asking if this would change anything up from a normal top swap.
i've read that **** plenty of times.
You're going to be using the same alternator bracket as the one you have unless you want to get a newer one so it'll be the same as for whatever alternator bracket you use.
97/98 1 elbow 99+ 2 elobows
