I have a 1997 Grand Prix GTP. It starts without an issue, but dies after 4-5 seconds. After research I noticed that it usually is the fuel pump resistor. Well, I went ahead and did the bypass and it ran good when I did that.Aside from the raw gas I could smell from the exhaust. Well, I go the boneyard and pulled litterally 15 of them. Well, EVERY single one I put on... it would die again. I'm kind of stuck. Don't really wanna spend the money on a new one if that not exactly it, because I highly doubt EVERY single one of those were bad. I'm leaning torwards the pump is bad and will only run right on high. I hear it kick on regardless of what resistor is in there. I also switched the fuel pump relay and the fuel pump speed resistor with no success(I seen they were the same part #). Any ideas would GREATLY be appreciated.
