Thread: code p0102
Results 1 to 3 of 3
  1. #1 OK, replaced maf, now its not shifting right
    SE Level Member hunter_alexander's Avatar
    Erie Pa.
    OK, cleaned all the sensors, maf was still bad. Replaced it.
    Took it to autozone, had them clear the codes. On the way it wasnt shifting right. Wouldnt shift gears correctly. Had to accelerate a lot to get it to shift.
    Autozone cleared the codes, and as soon as I started up the car the ses light came back on.
    I brought it home, parked it and disconnected the battery hoping that it will clear the codes all the way.
    Thoughts?
    Thanks for putting up with me as I learn this car. lol
    If all else fails, throw money at it..... that'll fix it.
    Check out my website here: http://craig.beesky.com/1987_olds_cutlass.htm
  2. #2 Re: code p0102
    Apr 2008
    Chillin at the Beach , VA
    I did a little research and this is really all I coould find to give you that code. Hope it can be of some help.
    SymptomsYou will likely not notice any serious drivability problems, although there may be symptoms such as a general decrease in power or sluggishness.
    Causes: A code P0102 may mean that one or more of the following has happened:
    The MAF may be disconnected, or a wiring connection may be bad
    The MAF may be dirty or otherwise contaminated (Note: if you use a reusable oiled air filter, be careful not to apply too much oil or that can contaminate the MAF).
    The MAF sensor may be faulty
    The vehicle computer may be faulty (very rare)
    Possible Solutions: The simplest thing to do is to reset the code and see if it comes back. Then start with the cheapest, easiest repair procedures:
    Verify that the Mass Air Flow Sensor wiring is connected properly and that there are no broken / frayed wires.
    Inspect for any air leaks near the MAF sensor.
    Take the MAF out and clean it using a spray cleaner such as brake cleaner or electrical contact cleaner. Be gentle with the sensor.
    Check the voltage of the MAF sensor (refer to a repair manual for vehicle specific information)
    Replace the MAF sensor.
  3. #3 Re: code p0102
    Erie Pa.
    Thanks. Yeah, I replaced the MAF as cleaning it didnt work. All fixed now.
    Thanks again.
  1. paint code
    By JCG's-GTP in forum General Tech Discussion
    Last Post: 04-13-2008, 08:41 PM
  2. Help with Web Software/Code
    Last Post: 03-15-2008, 10:25 PM
  3. Threw a code!
    By TFBuckeye in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-08-2008, 06:06 PM
  4. Blargh!!! code(s)!
    By Toasty in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-18-2008, 06:36 PM
  5. p0420 code on
    By fst in forum General Tech Discussion
    Last Post: 01-05-2008, 04:19 PM
