Thread: hars starting
Results 1 to 6 of 6
  1. #1 hars starting
    Jul 2010
    mobile, alabama
    2002 gtp having trouble starting and the wife smells fuel.Is this a fuel leak causing the hard starting issue?
  2. #2 Re: hars starting
    Winlsow, ME
    Can you see any fuel dripping when the fuel pump is turned on, if the fuel is draining out because of a broken line the engine might not be getting any fuel to start. Just follow the line starting from the tank and work your way towards the engine.
  3. #3 Re: hars starting
    Jul 2010
    mobile, alabama
    I haven't had a chance to look at it yet but I will surely check that first. My wife recently ran over a curb and the abs,tcs light started coming on the cruise control wouldn't work and the fuel miles to empty would flash.
  4. #4 Re: hars starting
    Winlsow, ME
    Ya, check where she she hit the curb on the vehicle maybe a line crimped or a wire broke of or came unplugged and is causing a malfunction. But that would be the easiest thing to do to start with anyways. Let me know what you come up with.
    NATEF Certified Auto Mechanic
    Maine State Inspection Mechanic
    Certified Amsoil Dealer
    EPA Air Conditioning Certified
  5. #5 Re: hars starting
    Jul 2010
    mobile, alabama
    problem was an easy fix, turned out to be a fuel rail oring.
  6. #6 Re: hars starting
    Willoughby, Ohio
    i love easy fixes, probably had fuel all over you engine huh?
  1. starting issues
    By duneking905 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-15-2010, 12:18 PM
  2. Starting to Mod
    By NewPrixOwner666 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-08-2009, 05:04 AM
  3. starting car trouble
    By rochaedkj in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-17-2009, 01:12 AM
  4. Starting Issues
    By BigBird in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-20-2009, 12:22 PM
  5. Help Car Hard Starting
    By rstark in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-15-2008, 06:24 PM
