Can the stock intake tube be used with a K&N filter on the end? I bought the 1foot intake tube from ZZP along with a filter but this tube is kind of a p.o.s.... If not then I gotta run to autozone and get 2 coupler reducers..
Damnit... any cheap alternatives for reducer's? I'm broke as a joke right now lol
Or...put a little rubber adapter on the end of the TB...cut a hole in it for the sensor and bolt the TB to the adapter...so...its more like a extended open cone.
Well I have a 4" 1foot long tube, and a 4" filter... what couplers should I get to attach it to the throttle body and the tube to the filter?
Sorry for stupid questions I'm new to all of this
I would say this:
http://www.zzperformance.com/grand_p...=647&catid=113
I think you also needed to select the "add aluminum ring" option when you ordered the tube, i believe it's for the filter side. Maybe they can ship you only that.
I used 4" dryer tube and some pvc pieces... it's ugly but works.
it won't affect to have the IAT outside. It is more hot right at the TB, but you get more flow. It won't harm the filter either. There's a sticky which i suppose you've already seen in this same section about open cone vs. fenderwell intakes.
If attaching the filter to the TB isnt harmful whats the point of having a tube at all???
That's an old discussion here and the sticky thread pretty much sums it up. It's always the Open cone VS. cold air intake argument.
check that thread out. it has some dyno info with both type of setups.
you can run it without an intake and not mess up your motor. put a cone on the throttle body, or run a piece of tubing closer to the fender. it doesnt matter so long as you dont have bends in it that arent necessary.
