Thread: Stubborn Exhaust Bolts
Results 1 to 15 of 15
  1. #1 Stubborn Exhaust Bolts
    New York
    I was lucky enough to pick up a DP from a friend of mine who was demodding his GP for a great price. So I put the car up on ramps and find that the stock DP bolts would much rather stay on the car. I've WD40'd the hell out of them but no dice. Is there something else I can hit them with or do I need to get a hold of a torch?
  2. #2 Re: Stubborn Exhaust Bolts
    GTX Level Member cerick08GP's Avatar
    Well, yes torching it is a good method. Also, WD-40 isn’t penetrating oil. In fact, WD-40 really isn’t even oil IMHO. There are tons of penetrating oils, pick one and spray some on. Then wait a day and re-spray . Then maybe a third time and you might not need that torch when you go to wrench them off. Good luck.
    Ten years of continuous driving excitement and counting!
    2008GP
    ||HV3 insert||PowerSlot rotors w/Hawks||LED interior||MSD 8.5mm
    2002GP||sold
  3. #3 Re: Stubborn Exhaust Bolts
    swift current,sask.
    Heat the f**k outta them, they will come out with little fuss. I mean like glowing hot hot...
  4. #4 Re: Stubborn Exhaust Bolts
    Portland Oregon
    PB Blaster is your friend. Shoot it with that, let it sit a day and you'll be able to pull em with hand tools
  5. #5 Re: Stubborn Exhaust Bolts
    You don't need a torch to heat exhaust bolts. Put the car on ramps etc and start it. Instant exhaust bolt heat up w/o worrying if you are torching too close to fuel lines etc.
    I have a 30" extension and Snap On swivel sockets that make the job easier.
  6. #6 Re: Stubborn Exhaust Bolts
  7. #7 Re: Stubborn Exhaust Bolts
    Windsor (ON) Canada
    My DP bolts were 100% rust welded together.. like the there was no identifying nut on the bolt... which was also rust down to a point...
    Demel cutting wheel and carbid drill bit.......fun
  8. #8 Re: Stubborn Exhaust Bolts
    Minnesota
    i put like a 2 foot pipe on the end of my wrench and kicked the **** out of it, no wd40 came right off lol leverage makes a world of difference
  9. #9 Re: Stubborn Exhaust Bolts
    SE Level Member chrisLB's Avatar
    Nov 2009
    canada
    got a breaker bar? it works every time, all the time lol i used a breaker bar when putting on my headers
  10. #10 Re: Stubborn Exhaust Bolts
    New York
    Hmm thanks for all the replies. I picked up a breaker bar from a buddy today and I'm heading out to grab some PB blaster as well. Fingers crossed.
  11. #11 Re: Stubborn Exhaust Bolts
    Apr 2009
    stockton ca
    mine came out with a cheap impact easy money
  12. #12 Re: Stubborn Exhaust Bolts
    New York
    Old DP is off, a delightful combo of PB blaster, heating the bolts via BillBoost's method and swearing did the trick just fine. Thanks for the help everyone!...I don't need any kind of PCM tuning for just a DP right?
  13. #13 Re: Stubborn Exhaust Bolts
    na you will be fine
  14. #14 Re: Stubborn Exhaust Bolts
    Topeka, KS
    I like the idea of just starting it and letting it run. It makes since PB Blaster is your friend.
  15. #15 Re: Stubborn Exhaust Bolts
    New York
    Everything is installed and running nice, thanks again for all the help.
  1. arp head bolts or tty bolts?
    By Lacboi in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-12-2011, 10:51 AM
  2. exhaust manifold bolts
    By jdmgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-05-2010, 10:09 PM
  3. Stock exhaust Bolts
    By Spartan GL in forum General Tech Discussion
    Last Post: 03-14-2010, 10:42 PM
  4. Exhaust Manifold bolts
    By Incomudrox in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-02-2008, 06:05 PM
