Thread: 180 degree Tstat
Results 1 to 4 of 4
  1. #1 180 degree Tstat
    Greensburg, PA
    So I have a PCM installed that is setup for a 180 degree t stat. I don't have it in yet( Still stock t stat) and am not gonna be able to get to it till this weekend? Well i guess what i want to know is it really bad to be running a PCM programed for a 180 t stat bu still running a stock one?
    Mods:3.4 pulley + recommended mods/ F-Body Front & rear GXP Calipers/ GMPP handling upgrade kit + otto strut brace/ SSC Gen 1 Springs on GR-2 struts/ Verde 5 18x8 Rims
  2. #2 Re: 180 degree Tstat
    Saraland Alabama
    no real difference, your fans just come on earlier than with a stock setup I believe
  3. #3 Re: 180 degree Tstat
    PA
    Yeah, it is not a problem if you are only doing it for a couple days. But your fans are going to be running almost constantly. While not really a big deal for short term, it can wear out the fans quicker and cause unnecessary drain on your alternator. And the more amps you are pulling, the less MPG you get.
    2001 GSE
  4. #4 Re: 180 degree Tstat
    Greensburg, PA
    Ok sounds good. yea im just gonna be running like this till Saturday.
  1. 70+ Degree temps for 2 days and then roof falls in!!!
    By GeddyLee in forum Off Topic Discussion
    Last Post: 03-05-2008, 10:16 PM
