Thread: Running issues with 2001 gtp S/C
Results 1 to 6 of 6
  1. #1 Running issues with 2001 gtp S/C
    Jul 2010
    Ypslanti, MI
    My 2001 gtp has been sending me for a loop! I changed the crank shaft and cam shaft sensors. That took care of my stalling and loss of tach and TCS. Now I have a horrible lag when i give more than half throttle. It shows full boost but it laggs something fierce>>>>>please help. Its a 2001 gtp 3800 series II s/c mostly stock.
  2. #2 Re: Running issues with 2001 gtp S/C
    clogged cat prolly, and maybe clean your maf sensor
  3. #3 Re: Running issues with 2001 gtp S/C
    GTX Level Member Rather B Blown's Avatar
    Dec 2008
    London, Ontario
    could be a misfire is your CEL on or does it flash?
    Quote Originally Posted by Reptile
    It sounds like you accidentally stuffed a midget in the downpipe, and he's hammering out an SOS to get out.
  4. #4 Re: Running issues with 2001 gtp S/C
    Minnesota
    MAF is my guess this just happened to me i cleaned it but that didnt do anything then i put a new one in and it fixed it
  5. #5 Re: Running issues with 2001 gtp S/C
    Jul 2010
    Ypslanti, MI
    I was throwing a misfire in cylnider 1 and MIL {malfunction Indicator Lamp} code. I changed plugs and cleaned MAF and Clean Throttle body and still the same. How would i go about uncloggin the CAT?
  6. #6 Re: Running issues with 2001 gtp S/C
    Jul 2010
    Ypslanti, MI
    also the CEL isnt on but i believe thats due to the MIL and dont really know how to go about fixing that ethier. While there is no light i am still pullin those two codes.
  1. Running rich at idle, causing idle issues.
    By matt5112 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-22-2010, 09:16 PM
  2. GTP Running Rough.. few new parts but still not running right.. HELP
    By azmattaz06 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-29-2010, 02:34 PM
  3. 2001 grand prix 3800 heat issues. HELP PLEASE
    By simplyfamous in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-23-2009, 06:47 PM
  4. 2001 GTP Trans into 2001 SE?
    By TechSmurf in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-28-2009, 07:11 PM
  5. 2001 Grand Prix GT: possible multiple issues...
    By mdurisseau in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-05-2009, 12:06 PM
