Thread: Finally fixing up the gp...need some help
Results 1 to 18 of 18
  1. #1 Finally fixing up the gp...need some help
    Oct 2008
    Northern Illinois
    Hopefully gonna start finally working on this thing tomorrow, but I've got a few questions before I do a few of the many repairs it needs.
    1. The blower motor is under the panel where the wipers bolt to, right? (No air comes on when I turn on the a/c).
    2. This will be my second set of hydraulic lower engine and trans mounts in a year, zzp solids the way to go?
    3. Turns out my sunroof is aftermarket, it's also alot smaller than a normal stock gp one and a pain in the ass to find parts for, should I just cut into the roof and swap a stock gp sunroof in there? I know a body guy so labor won't be TOO bad.
    4. Trans fluid...never been changed. My car has 126k on it now, I've heard changing the fluid after that long can shock the trans. Is this true or should I change it? If I shouldn't change the fluid should I at least change the filter?
    5. Last time I got an oil change they told me my pan was leaking, can't be anything major because the car never leaks oil onto the ground...so is this something that should get attention asap or can it wait?
    6. All 3 codes that are set to no report are showing up "not ready" on the emissions test. I thought once they were set to no report you can pass?
    Thanks guys, any help is always appreciated.
  2. #2 Re: Finally fixing up the gp...need some help
    Jan 2009
    Tallahassee, FL
    Get solid mounts, save some money and get them from a parts store.
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  3. #3 Re: Finally fixing up the gp...need some help
    Quote Originally Posted by BwolfGT View Post
    No...blower motor is under the passenger side of the dash. Have fun with that shiz...remove the passenger seat if your bigger than a 5th grader.
    If you don't care about rattling and feeling everything in your engine...then ya...get em. If not...get a new solid rubber engine/trans mount from AutoZone. I thought I told you to quit buying the fluid filled ones last time you had this issue?
    Your call jeeves. I'd have someone fix the one in there.
    It is true...but only if you FLUSH it. Just do a pan drop...replace the fluid you lost...put in a new filter...if you don't have a shift kit...I'd buy one while your in there. Get either an Intense-Racing one or a TransGo from Dave @ Triple Edge.
    If it isn't broke...don't fix it IMO. Oil pan gasket means dropping the cradle...it sucks.
    Yes...because no report means they won't show up...period.
    See the blue yo...and just for my reference...why in god's name are you running a N*? Your in no need for a throttle body that big.
    Last edited by blueguy; 08-15-2010 at 12:05 AM. Reason: Silly Rabbi, jews are for kids
  4. #4 Re: Finally fixing up the gp...need some help
    what about the ZZP shift kit?? Or do you not suggest that one.
  5. #5 Re: Finally fixing up the gp...need some help
    Well if you like $5 worth of plastic shims wrapped in packaging tape that took 20 minutes to get apart with no instructions tossed in a cam install kit box. Then sure.
  6. #6 Re: Finally fixing up the gp...need some help
    ok, i was just wondering because you didnt talk about that one. When i do my fluid change i wanna do a shift kit. and they come with instruction right?, but i do get the basics on what I have to do.
  7. #7 Re: Finally fixing up the gp...need some help
    Yes...just remember...you get what you pay for. Granted I sold mine to a local because I wasn't about to put those shims in my transmission...and I just waited and bought the whole damn transmission from Dave
  8. #8 Re: Finally fixing up the gp...need some help
    ok thanks BLUE, I think I will go with Intense because I dont plan on putting in a new tranny for a little while yet. (Knock on wood).
  9. #9 Re: Finally fixing up the gp...need some help
    Charles City, IA
    A transmission flush will not hurt your transmission at all.
    SMGPFC Two Nipple General
  10. #10 Re: Finally fixing up the gp...need some help
    VERY not true.
  11. #11 Re: Finally fixing up the gp...need some help
    Jersey
    x2 on everything nick or nic said, or however you spell it
    pm me, i have a complete Intense shift kit i pulled out from my other trans, all springs etc are still like new
    16' wrx sti- stock
  12. #12 Re: Finally fixing up the gp...need some help
    Charles City, IA
    VERY not true.
    Actually its 100% true, I have flushed transmission with 200k and they have been fine. If it effects your transmission in a negative way your trans was all ready shot. Now if some one does not know what they are doing when they flush it then yes they can mess up the transmission.
  13. #13 Re: Finally fixing up the gp...need some help
    I'm saying I know from seeing 4T65's around here that were being held together with the old fluid and flushing them out means you lose that bond...then PRESTO...new fluid...nothing is held together anymore...bye bye trans.
  14. #14 Re: Finally fixing up the gp...need some help
    Charles City, IA
    Drop the pan and see if there is any shavings in the pan, if not flush it.
  15. #15 Re: Finally fixing up the gp...need some help
    Oct 2008
    Northern Illinois
    Thanks alot blue, yeah I think I'll go with the pan drop right now...really don't feel like buying a new tranny in the near future. As far as the emissions...I guess I'll just buy an o2 emulator, that'll take me down to two not readys, I think you're allowed to have 2 and still pass.
  16. #16 Re: Finally fixing up the gp...need some help
    Oct 2008
    Northern Illinois
    Oh, and as far as the northstar goes, I've got bigger plans for this setup than what's on there now. And a friend of mine gave me an awesome deal on that and the ported blower when he went gen V.
  17. #17 Re: Finally fixing up the gp...need some help
    Not knocking it as long as you plan on at least camming the thing...or a big intercooler...just saying right now it PROBABLY isn't really helping you anymore than a Ported L67 would.
  18. #18 Re: Finally fixing up the gp...need some help
    Oct 2008
    Northern Illinois
    Yeah, hopefully this fall it'll be going cammed and i/c'ed, at least cammed.
  1. Help Fixing Foglights
    By GPGT40 in forum Audio, Security & Visual Electronics
    Last Post: 03-10-2010, 10:40 PM
  2. Fixing Headlights' Bouncing
    By vega in forum Visual/Body Modifications
    Last Post: 02-20-2010, 07:31 PM
  3. Fixing gear indicator
    By 2000SILVERSE3800 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-28-2009, 01:45 AM
  4. Fixing passenger window
    By GEMINIokc in forum General Tech Discussion
    Last Post: 08-23-2009, 09:30 PM
  5. fixing hud???
    By blowfishRus6 in forum General Tech Discussion
    Last Post: 12-23-2008, 10:45 AM
