Thread: L67 to L32 or?
Results 1 to 16 of 16
  1. #1 L67 to L32 or?
    SE Level Member NineD9GT's Avatar
    Dec 2008
    PA
    Ok, so, I spun a bearing in my higher mileage l67, and am not sure which way to go with this. Should I rebuild what I have, or get a salvage yard engine, get a newer L32, get a longblock...... and the list goes on. Just a rough estimate, I'm prob going to have about 2k in rebuilding my current engine if it needs bored out. The cheapest "master kit" I found was about $1200. Then machine work and other odds and ends. I'm guessing on about $800-$900 maybe more for an L32, prob cheaper for an L67. Any input on this? I can't seem to make up my mind. I'm not trying to build a racecar, just something to play with. This engine had 3.4 w/ supporting mods. Thanks
    99 GP GT L26 bottom end, Intense stage II cam, Ported L67 heads w/ LS6 springs, LS1 valve seals, 42.5# injectors, ported sc/intake, custom LS1 TB and MAF, custom FWI, 3.4 mps, NGK TR6, ZZP wires, 180 stat, etc...
  2. #2 Re: L67 to L32 or?
    get a mid/low miles l67 and be done with it.
  3. #3 Re: L67 to L32 or?
    Donating Users ninnyGTP's Avatar
    Nov 2008
    Moreno Valley, California
    L67's can be had for $400 or so
    L32's $800+
    If you can find an L32, it'll drop right in, will require your L67 rails, coolant temp sensor, map sensor, and o2 sensor. but that's it, can run it on your L67 tune
    98 Grand Prix GTP L32, GenV, n*, 3.2", 1.9 rr's, 3.29 gears. All that jazz SOLD
    99 Mustang GT Steeda UDPs, 3.73s, Pypes O/R xpipe, Accufab plenum, Steeda CAI, B&M ripper, MHS s2 cams, 10.5:1 compression (290whp/310wtq) SOLD
    01 SVT Cobra #3654, B&M Ripper, K&N FIPK2, MAC O/R xpipe
  4. #4 Re: L67 to L32 or?
    Dec 2008
    PA
    I would also need an adapter for my tb, right? I just found an l67 today, they want $600. They don't seem easy to come by here.
  5. #5 Re: L67 to L32 or?
    Dec 2008
    PA
    one more, if I get an L32, will my pulley work on the snout of the gen v charger, or even my whole snout?
  6. #6 Re: L67 to L32 or?
    you CAN'T run your L67 tune.
    Just like you CAN'T run your 3.4 pulley on there.
    You have to stay 0.2 pulley sizes larger with a Gen V blower.
  7. #7 Re: L67 to L32 or?
    GTX Level Member colindunn's Avatar
    Aurora, IL
    dont you need the L32 pcm also? and isnt it an electronic throttle not cable driven throttle? how would you change that
  8. #8 Re: L67 to L32 or?
    No...that is the point of the adapter plate.
  9. #9 Re: L67 to L32 or?
    Dec 2008
    PA
    Ok, so does the snout fit that blower? I can just buy a larger pulley for my mps. As far as the tune, I'm using hp tuners, so that can be adjusted.
  10. #10 Re: L67 to L32 or?
  11. #11 Re: L67 to L32 or?
    With your mods...a 3.6" pulley should suffice on a Jennyfive car.
  12. #12 Re: L67 to L32 or?
    Dec 2008
    PA
    now, the hard part is finding an l32.... If it's going to be a real pain, I'm just going to find another l67. Thanks for the info guys!
  13. #13 Re: L67 to L32 or?
    Aurora, IL
    there was one for sale here in MN like 900 bucks with 90k on it or something. but good luck!
  14. #14 Re: L67 to L32 or?
    SE Level Member ASCStinger's Avatar
    Jan 2009
    Rochester, NY
    you could also source an L26 and then swap over the L67 top end, I picked mine up for $450 with 38,000 miles.
  15. #15 Re: L67 to L32 or?
    Dec 2008
    PA
    That's a good idea... What size pulley would I need for that then? If I do that, I might consider throwing a cam in it...
  16. #16 Re: L67 to L32 or?
    SE Level Member 2001GTP's Avatar
    Apr 2009
    Phoenix, AZ
    There's a L32 (longlock) with 60K for $450 where I live. Going to go look at it tomorrow. I don't need it but for that price I will totally upgrade from my L67.
    3.6", 3" Downpipe, K&N CAI, 104's, PRJ Tune, P-Log, 180 t-stat,Res delete, wideband, boost gauge. 14.11" @ 99.5
l32, l67
