Thread: valve spring seal
Results 1 to 4 of 4
  1. #1 valve spring seal
    Donating Users
    Idaho Falls
    I am replacing a valve spring that broke. It also appears to have damaged the valve stem seal. Just the very upper part. I need to get the car running asap. The lower portion of the seal appears to be in fine shape.
    I will try to find one tomorrow but if I cannot will the seal still function with a small portion (less than 1/32") of the seal gone of damaged?
  2. #2 Re: valve spring seal
    Without a pic etc. I'd say you are taking the chance of it leaking a little oil into the cylinder. The good part is that you can burn a little oil w/o any real issues until you can order a set of seals and get back to 100%
  3. #3 Re: valve spring seal
    Charles City, IA
    I would get some seals. Any machine shop that does head work should have some.
    SMGPFC Two Nipple General
  4. #4 Re: valve spring seal
    Donating Users
    Idaho Falls
    You sir are correct, this is supposed to be my nice don't work on it too often car and I am sitting here thinking about doing something halfway.
    Time to source some seals hopefully someone local has some
  1. second cv axle seal..
    By JIMMY PITBULL in forum Pre-1996 4 speed Automatic (4T60E)(4T60E-HD)
    Last Post: 07-01-2010, 10:03 AM
  2. zzp valve spring retainers
    By 99prixgt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-13-2009, 07:35 PM
  3. front oil seal
    By sloppyjoe616 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-18-2009, 05:15 PM
  4. Valve Spring replacement...
    By Iron Indian in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-01-2008, 07:30 PM
