Thread: Wooo E85
Results 1 to 19 of 19
  1. #1 Wooo E85
    SE Level Member 99blkgtp's Avatar
    Jun 2010
    Avon,IN
    well ive had my headers and fwi for awhile and have been trying to decide exactly which way to go either meth or e85.......and E85 it is. I ordered my pump,harness,injectors and pulley today. I should be getting it all on and tuned late next week or weekend at prj performance. Im stoked to see how the car is gonna react.
  2. #2 Re: Wooo E85
    React by buying a smaller pulley...like a 3.25" or so.
  3. #3 Re: Wooo E85
    Jun 2010
    Avon,IN
    thats what i bought was a 3.25" pulley and #65 injectors and the racetronix pump and HD harness. Should pull pretty good.
  4. #4 Re: Wooo E85
    Charles City, IA
    Ship the pump and injectors to my house and I will inspect them for you
    SMGPFC Two Nipple General
  5. #5 Re: Wooo E85
    In Memoriam Rocket468's Avatar
    Yukon, Oklahoma, United States
    I never been a fan of e85. had it for a bit and yanked it off.
    My EX wifes other car is a broom.
  6. #6 Re: Wooo E85
    Jan 1970
    Maquoketa, Iowa
    It has been proven on at least one 3800 boosted setup to make more power than 110.
  7. #7 Re: Wooo E85
    Donating Users Tengis's Avatar
    Houston
    Lawlz. Our shop recently broke at least one (but probably two) dyno cam record using E85. Cheap, readily available (in some areas), and is basically race gas. Its the stuff that dreams are made of....
    344whp and 377wtq on a non-intercooled S1X setup on STOCK HEADS
    and
    373whp and 398wtq on an intercooled XP setup on STOCK HEADS
    Silver R32 Skyline GTS-T
    Satin Purple 97 GTP
    Blue 01 IS4 + M112 hybrid GTP
    Satin Black 98 Turbo GTP
    ZZP recommended installer - Kratos Concepts
  8. #8 Re: Wooo E85
    Jun 2010
    Avon,IN
    got my car back and im very pleased. Im gonna redo all my exhaust, colder plugs and a 160 stat, and take it back for one final tune. Lets see how long the tranny can take some abuse
  9. #9 Re: Wooo E85
    GT Level Member putskijr's Avatar
    Waterloo, Iowa
    180 stat would prob be the way to go...just my .02
    180* tstat, homemade FWI, autolite 605's, tuned by FoSho99, clear corners, 6000k hids, painted interior, and sum more
  10. #10 Re: Wooo E85
    Jun 2010
    Avon,IN
    Thats what it has in it right now and it runs about 190. He said i should put a 160* in it, and thats what i was gonna run it at least for the summer when its 95 degrees outside.
  11. #11 Re: Wooo E85
    no grand prix ever will benefit from running a 160* thermostat. its just too cold.
  12. #12 Re: Wooo E85
    The LED guy.... csssaint12's Avatar
    Nov 2009
    Duluth, Minnesota, United States
    I know people say that only certain engines can run e85. So I that a farse or is it that our engines can run e85 with certain set ups?
  13. #13 Re: Wooo E85
    that is dumb. anybody can run e85 so long as the fuel system can support it.
    for our cars you need bigger injectors, possibly a fuel pump, and a tune.
  14. #14 Re: Wooo E85
    If the car cant tell if theres E85 in there and its setup to run on regular gas and you put E85 in it and go WOT you'll go lean and blow your engine up.... THAT is why your car cant "support" E85
  15. #15 Re: Wooo E85
    Nov 2009
    Oh ok. Sorry I'm a rookie at this stuff. Just trying to learn. So how big of injectors do u need to run e85 and what would be a decent fuel pump to get to run e85
  16. #16 Re: Wooo E85
    depends entirely on your mod level and where you'd like to take it.
  17. #17 Re: Wooo E85
    Nov 2009
    Ok sounds good. I know this is under the supercharger area but with other mods could u run it in a n/a engine
  18. #18 Re: Wooo E85
    It would be pointless. You don't need a high octane in a N/A unless you are running some stupid 13:1 compression ratio or sorts like that.
  19. #19 Re: Wooo E85
    its not really a good idea.
