Thread: L32 into an older car...
Results 1 to 2 of 2
  1. #1 L32 into an older car...
    SE Level Member XgovernmentAgent's Avatar
    Edmond, Ok
    i just bought a L32 from an 05 GTP to put into my 87 Fiero GT, and am needing to know what needs to be done to adapt the returnless fuel system to a return style system. its been done, just looking at this from every way possible.
    also, so i can use this motor, i am going to use the 98-03 PCM since i cant use the L32 PCM... would i need the L67 harness instead of my L32 harness?
    does the GTP fuel filter have the FPR in it like on the LS1 motors? i cant find a listing for the GM part # anywhere. almost like the car doesnt use a fuel filter. GMPD doesnt even show it! what is the L32 stock fuel pressure?
    thanks for the help!
  2. #2 Re: L32 into an older car...
    if youre using the L67 setup, but the L32 motor, why not run L67 fuel rails..?
  1. L26 Oil pan on older W body
    By BillBoost37 in forum General Tech Discussion
    Last Post: 01-14-2010, 11:45 AM
  2. 07 GT same as older GTP???
    By technoweasel in forum Off Topic Discussion
    Last Post: 11-26-2009, 11:46 AM
  3. Older N* TB and MAF
    By DanGTP in forum General Tech Discussion
    Last Post: 05-20-2008, 12:31 PM
  4. Older stock wheels
    By Berger in forum Tires & Wheels
    Last Post: 03-31-2008, 12:56 AM
  5. Games for when you get older!!!
    By 2Fast4U in forum Off Topic Discussion
    Last Post: 02-27-2008, 11:15 PM
