Thread: WTF????????
Results 1 to 7 of 7
  1. #1 WTF????????
    GT Level Member duane9586's Avatar
    Apr 2008
    ny
    what causes a pushrod to bend? Could a rocker have loosened up. It did it when i was pulling into work. I wasn't getting on it. the rocker next to it was off the pushrod also but was not bent. Any idea's??? thanks for any input
    180*, Overkill, K&N, MSD, GEN V, AL 104's,ZZP Shift kit,SD Headers,1.9rr's, 90#,3.2zzp,0KR, 8K HID,Was a Base Model
  2. #2 Re: WTF????????
    Charles City, IA
    Your rocker seized up or the valve is stuck.
    SMGPFC Two Nipple General
  3. #3 Re: WTF????????
    Apr 2008
    ny
    rockers are good. i put in 2 new pushrods and so far so good
  4. #4 Re: WTF????????
    May 2008
    staten island,NY
    when they were installed was the rocker bolt hole completely clean? oil in the hole will make the bolt not torque down
  5. #5 Re: WTF????????
    Apr 2008
    ny
    they were installed at least 10k ago
  6. #6 Re: WTF????????
    Doesn't mean it couldn't have very slowly come loose. I bent a pushrod...you know what else I found? Busted valve too. Does it misfire or anything now?
  7. #7 Re: WTF????????
    Apr 2008
    ny
    no miss. it runs great
wtf
