Thread: cradle bushings
Results 1 to 5 of 5
  1. #1 cradle bushings
    Donating Users bbptech's Avatar
    Box Elder, South Dakota
    where can i get new ones? through dealer or?
    ZZP 10.4mm's, ZZP S2 IC, 3.4, 3.0, Ported Gen V, ZZP Headers, ZZP CNC Heads, ZZP 78mm TB, ZZP Aluminum Valve Covers, Meziere Electric WP, ZZP Fuel Pump, ZZP Fuel Logs, 65 Mototrons, 3.29's, 2500 Stall. Tuned by GLANZERGTX and Kyle. E85 Converted, 21* Timing
  2. #2 Re: cradle bushings
    Aren't they pressed into the subframe?
  3. #3 Re: cradle bushings
    GTX Level Member Jakegday's Avatar
    Nov 2008
    Fremont Nebraska
    gmpartsdirect.com has them. not sure about them being pressed in or not.. nothing a simple hydraulic press cant take care of
    2001 GT: cat/ubend/resonator delete, zzp PLOG, custom intake, DHP pcm
  4. #4 Re: cradle bushings
    how do i obtain the part numbers to look up the parts? i have figure out how to look them up on there site.
  5. #5 Re: cradle bushings
    GT Level Member Vegas~Blown's Avatar
    Aug 2008
    vegas
    p/n's for the rears....
    10249631 -- upper insulator (purple) -- 23.60
    10249638 -- lower insulator (purple) -- 12.71
    10203413 -- body washer -- 7.13
    10410940 -- bolt -- 5.11
    prices, each, are from monster parts from about 2 months ago.
  1. cradle bolts....
    By Piggy in forum General Tech Discussion
    Last Post: 08-17-2009, 02:26 PM
  2. What exactly are the cradle bolts?
    By trenaro in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-07-2009, 03:15 PM
  3. Slide Pin Bushings
    By GP Modder in forum Brakes/Suspension/Chassis
    Last Post: 12-08-2008, 02:10 AM
  4. Installing Cradle (cradle alignment pins)
    By JJ91284 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-16-2008, 05:47 PM
