Thread: Changed bad wheel hub and (abs/tcs) light still on
Results 1 to 20 of 26
  1. #1 Changed bad wheel hub and (abs/tcs) light still on
    SE Level Member azmattaz06's Avatar
    Feb 2009
    Tucson
    Any ideas? before fixing other things, Would i have to reset the codes or the computer to erase the code that's making the light pop up? if so how? i left my battery unhooked for a good half hour and the lights are still there.. any ideas?
  2. #2 Re: Changed bad wheel hub and (abs/tcs) light still on
    Donating Users
    South Deerfield, MA
    No, you don't have to reset the code. It will clear when the problem is fixed. Did you forget to plug in the new hub by any chance? I did that once. Fortunately, you can reach it without taking the wheel back off. Did you get the abs code read to see what it says. Could be one of the other 3 hubs is bad, a bad abs module or a broken wire somewhere.
    2002 GTP: GMPP Sway Bars, BMR trailing arms, KYB AGX/Vogtlands, 12" brake upgrade
    Modified SSAC headers, K&N Intake, 3.4 MPS, S1X, Gen V, 104's, HPTuned.
  3. #3 Re: Changed bad wheel hub and (abs/tcs) light still on
    GT Level Member jdmgtp's Avatar
    MI
    how would one scan the abs system? I think you can use a tech 2 but I'm not sure. Any other ways?
    2000 GTP, 3.2 pulley, SD headers, 3" exhaust, modded 1.9's, custom CAI, LS6 maf, ported blower/ TB, HPT, 65 lb injectors, E85 in the summer, LM-1 wideband, 180 stat, autolite 104's, GMHD suspension kit. 13.2@104 on street tires w/o ported s/c
  4. #4 Re: Changed bad wheel hub and (abs/tcs) light still on
    Donating Users
    South Deerfield, MA
    A mechanic friend of mine uses a Snap-On scanner that will read the codes. I don't know for sure any others, but I bet somebody else makes a scanner that can read the abs codes.
  5. #5 Re: Changed bad wheel hub and (abs/tcs) light still on
    Charles City, IA
    Pretty much anyshop will have a scanner that will read abs codes.
    SMGPFC Two Nipple General
  6. #6 Re: Changed bad wheel hub and (abs/tcs) light still on
    MI
    with my luck they'll want to charge me just to scan it. To bad hptuners doesn't, I guess I'll have to just bug my buddy to borrow the tech 2 from his work.
  7. #7 Re: Changed bad wheel hub and (abs/tcs) light still on
    GT Level Member Preotic's Avatar
    Missoula, MT
    The abs is in the bcm only techII's can read bcm codes. My friend works at a chevy dealership so i never pay for the tech II scans. Anyways one day my abs light came on and we scanned it. It showed left front was the problem. We replaced the hub and the light still stayed on.
    We then were sure it was in the wiring. If you follow the wiring from the abs sensor to the bcm you'll find a midpoint harness/plug. We seperated the plug and with the help of a multimeter we found the plug was bad. We had to cut out the plug and replace it with a new one.
    L26,Xp, zzp trans,3.29's,2700 conv, slp headers/catback, diy ported heads/LIM, 3 angle valve job,.052 MLS hg, outlet ported Gen V, 3.6, N*, LQ4, 4" FWI, agx's, ssc's, f-bodys, gmpp sway's +stb's
  8. #8 Re: Changed bad wheel hub and (abs/tcs) light still on
    GTP Level Member Scimmia's Avatar
    QCA, IA
    Quote Originally Posted by Preotic View Post
    Not true. I know for sure the Snap-On scanner and HP Tuners will both read codes from the BCM, and I'm sure there are others as well.
    2001 Buick Regal LS - Almost Stock
  9. #9 Re: Changed bad wheel hub and (abs/tcs) light still on
    Donating Users
    South Deerfield, MA
    X2. I watched a snap-on scanner pull the codes saying the right rear speed sensor was bad on my last GP.
  10. #10 Re: Changed bad wheel hub and (abs/tcs) light still on
    MI
    Quote Originally Posted by Scimmia View Post
    and I know for a fact that hptuners won't.
  11. #11 Re: Changed bad wheel hub and (abs/tcs) light still on
    QCA, IA
    Quote Originally Posted by jdmgtp View Post
    Do I need to post a screenshot? I've used HPTuners a number of times to read BCM codes, including those for the wheel speed sensors.
  12. #12 Re: Changed bad wheel hub and (abs/tcs) light still on
    GTX Level Member Jakegday's Avatar
    Nov 2008
    Fremont Nebraska
    your hub/bearing wasnt the problem, but rather the wires going to it...
    2001 GT: cat/ubend/resonator delete, zzp PLOG, custom intake, DHP pcm
  13. #13 Re: Changed bad wheel hub and (abs/tcs) light still on
    MI
    would you please?
  14. #14 Re: Changed bad wheel hub and (abs/tcs) light still on
    MI
    Quote Originally Posted by Jakegday View Post
    sorry for the hijack, good to hear you got it fixed.
  15. #15 Re: Changed bad wheel hub and (abs/tcs) light still on
    Nov 2008
    Fremont Nebraska
    what are you talking about???? i was never having any problem.....
  16. #16 Re: Changed bad wheel hub and (abs/tcs) light still on
    MI
    whoops, you weren't the OP.
  17. #17 Re: Changed bad wheel hub and (abs/tcs) light still on
    Charles City, IA
    Well I guess I will just have to start listing scanners that will.
    tech-II thats a given
    snapon modis
    snapon ethois
    snapon solus
    snapon red brick
    hptuners
    otc genisys
    napa genisys
    those are the ones that I have used before.
  18. #18 Re: Changed bad wheel hub and (abs/tcs) light still on
    MI
    would someone please show me where hptuners can scan abs?
  19. #19 Re: Changed bad wheel hub and (abs/tcs) light still on
    Nov 2008
    Fremont Nebraska
    snapon modis
    snapon ethois
    snapon solus
    snapon red brick
    hptuners
    otc genisys
    napa genisys
    also the Actron cp9449 reads abs codes, and can be had for less then $150 brand new on ebay
  20. #20 Re: Changed bad wheel hub and (abs/tcs) light still on
    HPT will report the DTC for the speed sensor issue. That's if it's the right car/year.
    HPT reports for 2000 Regal and most W bodies 97+, but will not for the 1997/1999 Bonneville.
  1. for those of you that changed. upgraded rad
    By kuntzie in forum General Tech Discussion
    Last Post: 07-04-2010, 09:24 PM
  2. Changed It Up A Bit (New Pics)
    By Dboy23 in forum Off Topic Discussion
    Last Post: 05-12-2010, 03:33 PM
  3. So alot has changed.....
    By GTPJOE90 in forum Visual/Body Modifications
    Last Post: 03-23-2010, 05:27 PM
  4. Replies: 16
    Last Post: 01-23-2010, 09:43 AM
