Thread: Engine misfire HELP!!
Results 1 to 13 of 13
  1. #1 Engine misfire HELP!!
    TDCRacing
    Guest
    Ok so i put some headers and rockers on the car and had everything torn apart...the car runs...but i am getting a missfire code on my hpt scanner...I think it is in the back bank of cylinders...i am getting spark to the back bank for sure...i think it may be fuel injector related...i sprinkeled some water on eack of the header tubes on the back and front and when they hit the front they evaporated immeditely. while on the back they just sat there. i cant see the engine running on 3 cylinders but that is just what i saw.
    Is there anyway to tell on my scanner witch one is misfiring??
    Is there anyway on my scanner to tell if my injectors are working right??
    And yes all the plugs are on right...i dont know what else to check some one help
  2. #2 Re: Engine misfire HELP!!
    Donating Users blowfishRus6's Avatar
    g.a.
    ouch. thats crazy. hope you get er fixed
  3. #3 Re: Engine misfire HELP!!
    TDCRacing
    Guest
    After reptile told me the firing order and i pulled all the plugs i realized i had 2 of the plug wires switched up....DUH!!!
  4. #4 Re: Engine misfire HELP!!
    Oklahoma
    You know, I like to write stuff like this down so I can make fun of you for the rest of your life.
    Nah, just kidding, glad you got it figured out and fixed.
  5. #5 Re: Engine misfire HELP!!
    Bastard Reptile's Avatar
    Kansas City, MO
    Quote Originally Posted by TDCRacing View Post
  6. #6 Re: Engine misfire HELP!!
    PA
    Just as a note, I know my PT can tell me exactly what cylinders are mis-firing. Does HPT not do this?
    2001 GSE
  7. #7 Re: Engine misfire HELP!!
    Kansas City, MO
    I'm almost positive that it does.
  8. #8 Re: Engine misfire HELP!!
    g.a.
    haha yea that might help
  9. #9 Re: Engine misfire HELP!!
    GTX Level Member Andrew_99GTP's Avatar
    New Salem, ND
    I thought you had them on right Just goes to show that no matter how sure you are about something, it never hurts to double check. Glad to see you got it figured out though.
    Red 2dr 99 GTP"Old" Z7 t66, A/A IC'd, Custom Heads, 65# Inj, ST2 Cam, Meziere Elec Pump, JP Double Roller(with machined crank gear), Plogs, PLX W/B, Powrtuner SOLD
    "New" 2007 Duramax ccsb with a few mods
  10. #10 Re: Engine misfire HELP!!
    Kansas City, MO
    What's funny, and this is a true story, I had someone actually put the plug wire boot on the exhaust manifold stud. You may think it's silly, but it was close, and with gloves on it feels like the spark plug.
  11. #11 Re: Engine misfire HELP!!
    TDCRacing
    Guest
    Should have a nice size paperback by now huh?
  12. #12 Re: Engine misfire HELP!!
    TDCRacing
    Guest
    Quote Originally Posted by Reptile View Post
    Yea i know it is close...I thought for a second that it was the spark plug also...but then i felt the threads....
  13. #13 Re: Engine misfire HELP!!
    SE Level Member BlackGS's Avatar
    Central Jersey
    HPT will scan individual cylinders for misfires. Just add each cylinder from Engine Diagnostics into the Table Display by right-clicking on an empty cell and selecting Insert.
    2000 Regal GS | Stattama Twin-Charge with Comp Turbo 6765 | 12.55 @ 110 15psi | Now running 20psi on E85!! |
  1. Which engine oil?
    By Deezul_AwT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-11-2008, 04:41 PM
  2. P1380-Misfire Detected-Rough Road data not available
    By t24moore in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-20-2008, 09:07 AM
  3. #4 cylinder misfire
    By JCG's-GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-11-2008, 06:16 PM
  4. Misfire like no other
    By MTXGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-24-2008, 10:02 AM
  5. NEW use for an engine hoist!!!!
    By Trannyman95 in forum Off Topic Discussion
    Last Post: 02-08-2008, 11:51 PM
