Thread: Pictures.. engine look normal?
Results 1 to 12 of 12
  1. #1 Pictures.. engine look normal?
    Apr 2008
    Engine with 70k miles on it just wondering about a few wet looking spots
  2. #2 Re: Pictures.. engine look normal?
    Barksdale AFB, LA
    Leaking LIM gaskets. Common issue.
    2009 Subaru Impreza WRX STI
  3. #3 Re: Pictures.. engine look normal?
    Feb 2008
    That's actually clean compared to mine. Yup, it's the LIM leaking...
  4. #4 Re: Pictures.. engine look normal?
    Moore, Oklahoma
    LIM leaking and Valve covers too. I bet if you pull off that plug wire retainer on the front you'll see a nice amout of built up oil.
    Shawn W. Larsen
  5. #5 Re: Pictures.. engine look normal?
    PA
    Valve covers are leaking a little bit, but not too bad. But LIM is leaking for sure. I would make sure to get that taken care of asap. And just do the valve covers while you are at it.
    But compared to what my car was like when I did everything at 160k, that is nothing...
    2001 GSE
  6. #6 Re: Pictures.. engine look normal?
    Wichita, KS
    Pretty mild compared to what I have seen myself too.
    You know your LIM gaskets are bad when you have coolant puddling around your injectors.
    Do both, LIM gaskets and valve cover gaskets and might as well replace the grommets around the bolts of the valve cover as well.
    ~F~
  7. #7 Re: Pictures.. engine look normal?
    Apr 2008
    I pressure washed the engine bay and im planing on switching to valvoline maxlife so i'll keep an eye on it to see if it comes back
    Thanks everybody
  8. #8 Re: Pictures.. engine look normal?
    alright, learning time 4 me. wtf is the lim gasket?
  9. #9 Re: Pictures.. engine look normal?
    GT Level Member Meemperor's Avatar
    Toronto, ON, Canada
    Lower Intake Manifold.
    Lumpy Gen 3
  10. #10 Re: Pictures.. engine look normal?
    Saraland Alabama
    Quote Originally Posted by golden_c_ninja View Post
    Thanks everybody
    maxlife won't fix it, it has additives to swell gaskets, but doesn't work well on the new types
  11. #11 Re: Pictures.. engine look normal?
    Apr 2008
    any other suggestions untill i can get it replaced?
  12. #12 Re: Pictures.. engine look normal?
    Wichita, KS
    Its not bad yet, I would say another year of every day driving it will be worse for sure. This is the starting stage of it.
    Until you can make repairs keep an eye on your coolant level in your coolant reservoir, but very doubtful you will be loosing THAT much as mush as it is seeping now. Once a week, pop your head under the hood and take a look.
    ~F~
  1. Car Pictures
    By archemedes in forum General Grand Prix Discussion
    Last Post: 01-05-2022, 05:21 AM
  2. Clay Bar Pictures
    By Street Wolf in forum Visual/Body Modifications
    Last Post: 02-04-2011, 08:41 AM
  3. Pictures area
    By archemedes in forum Forum Bugs/Suggestions
    Last Post: 02-18-2008, 05:20 PM
  4. Pictures
    By 03GPScottyd in forum General Tech Discussion
    Last Post: 02-10-2008, 11:32 PM
  5. Posting pictures
    By aquase in forum Forum Bugs/Suggestions
    Last Post: 01-03-2008, 11:37 PM
