Thread: XP Cam setups
Page 2 of 2 FirstFirst 12
Results 21 to 27 of 27
  1. #21 Re: XP Cam setups
    Donating Users nascartech's Avatar
    Abbotsford, British Columbia, Canada
    didn't he say he was gunna use a double roller timing chain though
    Manley 130's.
    I have them...Intense used to sell them...I don't know what happened to them...Crow 105's will work just fine with a XP though.
    01 GTP is3 cam 130 springs double roller 60lb injectors lq4 maf headers 4000 stall lowered
    sold 97 GTP stock
    Sold 2001 gp gt ssm90 plog dp 3.8 208 whp 265 at the crank 14.8 1/4
  2. #22 Re: XP Cam setups
    Quote Originally Posted by nascartech View Post
    whats your point? you dont need 130# springs to run a double roller...i ran a double roller on STOCK valve springs...
  3. #23 Re: XP Cam setups
    Donating Users bbptech's Avatar
    Box Elder, South Dakota
    i have a double roller but if its not needed i wont use it. in fact i much rather wouldnt. I would rather run stock timing chain, and just put new chain and dampner on.
    I will probably skip the 90's because of valve float and go with a PBM 110 spring instead of a crow or comp 105. I have a set of comp 105s but dont want to run them cause of issues.
    ZZP 10.4mm's, ZZP S2 IC, 3.4, 3.0, Ported Gen V, ZZP Headers, ZZP CNC Heads, ZZP 78mm TB, ZZP Aluminum Valve Covers, Meziere Electric WP, ZZP Fuel Pump, ZZP Fuel Logs, 65 Mototrons, 3.29's, 2500 Stall. Tuned by GLANZERGTX and Kyle. E85 Converted, 21* Timing
  4. #24 Re: XP Cam setups
    crow > comp
  5. #25 Re: XP Cam setups
    looks like im going to order some crows off the intense site. Which retainers should i use?
  6. #26 Re: XP Cam setups
    Charles City, IA
    the ls style.
    SMGPFC Two Nipple General
  7. #27 Re: XP Cam setups
    Manley Titanium ones.
    WIN
  1. Wideband setups, tell me about yours...
    By Iron Indian in forum Off Topic Discussion
    Last Post: 09-17-2009, 12:38 PM
  2. 3.4 reliable setups ideas what shud i do
    By Soloaded in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-19-2009, 11:52 PM
  3. intercooler setups
    By robahr24 in forum General Tech Discussion
    Last Post: 01-24-2009, 09:02 PM
  4. different exhust setups
    By cobraz in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-19-2008, 03:37 AM
  5. TB for Turbo setups
    By japslpr in forum Turbo
    Last Post: 09-03-2008, 07:06 AM
