Thread: Sunroof Measurements
Results 1 to 7 of 7
  1. #1 Sunroof Measurements
    Donating Users kfish's Avatar
    Ohio
    does someone wanna grab the measurments of the factory sunroof for me? mine has a leaky aftermarket, and im hoping its about the same size as factory or a bit smaller. Or do you think it would be easier to have a new one put in? the motor went out on this one, and i cant get a new motor for it.
  2. #2 Re: Sunroof Measurements
    SE Level Member Spazztic2003's Avatar
    Oxford, MI
    sorry to necro a thread, but i would really appreciate an answer for this as well as mine has gone out too.
    A fan of Pontiac and their cars since my birth in Pontiac.
    Proud owner of the world's worst '98 GTP, falling apart in every way!
  3. #3 Re: Sunroof Measurements
    GT Level Member silvermistchick's Avatar
    Jan 2009
    Atlanta, GA
    im going outside now to mess with mine ill be in 10 mins with info
  4. #4 Re: Sunroof Measurements
    Jan 2009
    Atlanta, GA
    21x33.5
  5. #5 Re: Sunroof Measurements
    is that the size of the hole?
  6. #6 Re: Sunroof Measurements
    Jan 2009
    Michigan
    if you're thinking you're going to put a factory roof in you cant... what kind of sunroof is it? webasto? inalfa? asc? i install aftermarket webasto roofs. try to find a manufacture's name by the seal, on the front, when you open the glass, i may be able to get a motor for you. If it's one I work with of course. Also maybe look on the motor itself. they have a manufacture's name on them as well if you dont see one anywhere else. Take picture of it if you need to and Ill see if it looks familiar.
  7. #7 Re: Sunroof Measurements
    Ohio
    the bastard is siliconed shut haha. i really couldnt tell you the name. all i know if when it rains it leaks and i dont like it. the install job was ****ty as well.
  1. sunroof
    By kpowell in forum General Tech Discussion
    Last Post: 04-09-2010, 12:53 PM
  2. Is Sunroof the same 97-03?
    By Tfreeds in forum General Tech Discussion
    Last Post: 02-14-2010, 03:22 PM
  3. Sunroof?
    By mike171562 in forum General Tech Discussion
    Last Post: 08-26-2009, 12:21 PM
  4. Sunroof...
    By SlowM90 in forum General Tech Discussion
    Last Post: 07-28-2009, 04:57 AM
  5. Help with sunroof!
    By kbwent in forum General Tech Discussion
    Last Post: 02-22-2009, 08:55 AM
