Thread: turning stock 3800 into supercharged?
Results 1 to 19 of 19
  1. #1 turning stock 3800 into supercharged?
    Apr 2008
    my buddy recently bought the grand prix gt. i was just curious on everything he needs to bolt up that supercharger. i imagine a new pully kit different gaskets and the supercharger itself.
    o and one other question would be does the stock n/a 3800 have the same internals as the supercharged 3800 or must there be upgrades with the internals also.
    thanks, kyle
  2. #2 Re: turning stock 3800 into supercharged?
    Transmission Expert Trannyman95's Avatar
    Fort Wayne, IN
    Hi Kyle, the bare block is about the only thing the same between the two engines.
    -The supercharged engine has stronger pistons with a lower compression ratio
    - different rods
    - crank balanced different
    - different flexplate again balanced different
    - crank pulley/balancer balanced different and has an extra section machined on the end for running the supercharger belt
    - cylinder heads have holes machined in intake runners for fuel injectors
    - larger fuel injectors and completely different fuel rail
    - cam sprocket for timing chain retarded 2 deg on NA engine
    - intake manifold
    - valve covers
    - coil pack bracket and all associated sc belt pulleys and brackets
    - transmissions has larger torque converter and differential, different gearing
    - pcm to match the above differences
    Many guys do what is called a top-swap which basically is using from the heads and up off of a supercharged engine. This will give you the topend but you retain your stock NA bottom end and trans and this requires custom pcm tuning to make work. There is a company ZZP that sells or used to sell modified lower intake manifolds and supercharger housings that allow you to retain your stock heads but cost wise you really arent saving anything, it just makes the job easier to do.
  3. #3 Re: turning stock 3800 into supercharged?
    SE Level Member DRWBRTq19's Avatar
    Jefferson City MO
    Quote Originally Posted by Trannyman95 View Post
    Is the bracket just different b/c of the pulleys, or is there another reason? I honestly could not see the difference, but that doesn't mean I overlooked it.
    Drew
  4. #4 Re: turning stock 3800 into supercharged?
    SE Level Member prettyprix's Avatar
    Oct 2008
    Columbus, Ohio
    I have been planing on doing the same thing, I was going to get the parts from a junkyard hopefully then my uncle and i were going to put it in. Any guesses on how much everything would cost from a junkyard?
  5. #5 Re: turning stock 3800 into supercharged?
    Apr 2008
    well thanks for the info
  6. #6 Re: turning stock 3800 into supercharged?
    Jan 1970
    Maquoketa, Iowa
    Top swap is $600 plus depending on where you get the parts and piece it together, or get a kit. You will make more hp than the gtp's becuase of the higher compression that the gt's bottom end comes with.
  7. #7 Re: turning stock 3800 into supercharged?
    Apr 2008
    where can you get one of these kits. i cant find any
  8. #8 Re: turning stock 3800 into supercharged?
    Jan 1970
    Maquoketa, Iowa
    Here's a kit, but rather just use it as the parts list... look in the for sale section for parts, you could go to the junkyard and get these also...
    W Body Store Supercharger Conversion Kit
  9. #9 Re: turning stock 3800 into supercharged?
    Apr 2008
    cool thanks. its alot of work but i told my bud he shuda just bought a gtp
  10. #10 Re: turning stock 3800 into supercharged?
    GT Level Member RooK's Avatar
    Apr 2008
    Southern KY
    Just buy a GTP engine from Ed or a junkyard and drop it in. Less labor and time involved, unless you were planning on having heads and things reworked anyway.
    Most places that part out a swap kit want around $1k for the parts. You can get a whole L67 for around $600 with decent mileage.
    '13 Stang - V6 MT82 - GHIG
    '00 Grand Prix SE - Pink (L67 Swapped/XP Cam/3.25")
    '98 Grand Prix GTP - Black ($500 toy with broken trans. )
    '01 Bonneville SE - Sitting on a hillside needing attention
  11. #11 Re: turning stock 3800 into supercharged?
    Quote Originally Posted by RooK View Post
    the point of this is for the higher compression, not the supercharger. if you just want the blower then an l67 might be the way you want to go as its easier by a large amount.
    if youre good at finding parts you can do this entire swap for less than $600 including the gaskets and sealants you need to buy.
    i wouldnt attempt this if you dont know your way around the engine.
  12. #12 Re: turning stock 3800 into supercharged?
    GT Level Member GTX's Avatar
    Apr 2008
    Vallejo,Ca
    has anyone here tried this? if so what are the gains you are seeing? is it worth the effort?
    COMP G
  13. #13 Re: turning stock 3800 into supercharged?
    Barksdale AFB, LA
    Plenty Impala owners have done it. One guy is down to 13.76 on a 3.4". Not really many other mods.
    2009 Subaru Impreza WRX STI
  14. #14 Re: turning stock 3800 into supercharged?
    i did it. it was fun for the three days it ran. (forgot the oil pump gear for about 30 seconds of startup, spun bearing 3 days later)
    its a lot of work. if you dont know how to work on a motor, find someone that does or pray that you are meticulous enough to figure it all out and do it right.
  15. #15 Re: turning stock 3800 into supercharged?
    Barksdale AFB, LA
    Why were you messing with the oil pump gear on a top swap?
  16. #16 Re: turning stock 3800 into supercharged?
    put in a double roller and cam. didnt realize the jp was a two piece setup and slapped it back together without realizing it. first few starts, no oil pressure. by the time i got it back together it was halfway gone already.
    it drove for three days after that before i spun a bearing, just to show how tank-like these engines are. wish i would have kept that cam..TEP is MEAN!
  17. #17 Re: turning stock 3800 into supercharged?
    Barksdale AFB, LA
    Well, that shouldn't factor in on a regular top swap then. Most wouldn't even open the front cover.
  18. #18 Re: turning stock 3800 into supercharged?
  19. #19 Re: turning stock 3800 into supercharged?
    Apr 2008
    Vallejo,Ca
    i might hit the yards around here and buy a NA bottom and then the SC top and assemble this on the stand. i wouldnt do this with only one engine (in the car already) on hand, too many variables
    COMP G
  1. Supercharged issues?
    By lt1transam in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-22-2008, 02:56 PM
  2. Supercharged G8 vid from Europe
    By Trannyman95 in forum Off Topic Discussion
    Last Post: 04-07-2008, 04:41 PM
  3. My 3800
    By Street Wolf in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-12-2008, 03:19 PM
  4. 1st! Vibration while turning '93 Lumina
    By Abrasive in forum Chevrolet Lumina
    Last Post: 01-06-2008, 08:36 PM
