Thread: stock 04 grand prix GTP
Results 1 to 20 of 22
  1. #1 stock 04 grand prix GTP
    Jun 2010
    chicago
    What is the stock boost on a 04 grand prix gtp?
  2. #2 Re: stock 04 grand prix GTP
    GTX Level Member Rather B Blown's Avatar
    Dec 2008
    London, Ontario
    7-8lbs i think
    Quote Originally Posted by Reptile
    It sounds like you accidentally stuffed a midget in the downpipe, and he's hammering out an SOS to get out.
  3. #3 Re: stock 04 grand prix GTP
    Charles City, IA
    0-10 depending on the condition of the engine,exhaust, and supercharger.
    SMGPFC Two Nipple General
  4. #4 Re: stock 04 grand prix GTP
    Probably 5-6 on a stock car and pulley.
  5. #5 Re: stock 04 grand prix GTP
    Jun 2010
    chicago
    all i got on it is a k&n air filter n the motor is brand new and the trans and supercharger is got 50,000 miles on them
  6. #6 Re: stock 04 grand prix GTP
    Portland Oregon
    I see numbers in the 11's on a 3.6 with headers and an open cone
  7. #7 Re: stock 04 grand prix GTP
    Jun 2010
    chicago
    would an cold air intake n catback exhaust void an warrantee?
  8. #8 Re: stock 04 grand prix GTP
    Charles City, IA
    no, but they might help spelling and grammar.
  9. #9 Re: stock 04 grand prix GTP
    SE Level Member Milestone's Avatar
    May 2008
    I was seeing 9lbs stock
    Modded.......Yes sir
  10. #10 Re: stock 04 grand prix GTP
    GT Level Member BoostedComp's Avatar
    Youngstown
    i was getting about 9 also.
  11. #11 Re: stock 04 grand prix GTP
    GT Level Member wlmrt6's Avatar
    Sterling
    i had 9 stock and about 10.5-11 with my 3.6
  12. #12 Re: stock 04 grand prix GTP
    Hagerstown,Md
    9-10 psi with my 3.25
  13. #13 Re: stock 04 grand prix GTP
  14. #14 Re: stock 04 grand prix GTP
    A million PSI on my old thread
  15. #15 Re: stock 04 grand prix GTP
    Dec 2010
    Noble, Oklahoma
    Lol
    Boostin To A City Near You
  16. #16 Re: stock 04 grand prix GTP
    GT Level Member TheAce144's Avatar
    Dec 2010
    Montreal, Canada
    All I know is that the 99-03 GTP running on a 3.4" pulley has the same amount of boost as the 04-09 GTP with a stock pulley, which is 3.8"...maybe around 8-9 lbs?
    04 GTP CompG: SSAC Headers, 3.6" Modular Pulley System, Autolite 104, NGK Spark Plug Wires, CAI, ZZP 180 T-Stat, Overkill PCM (Custom Street Tuning By Will), Goodyear Eagle F1 Tires, Hawk HPS Brake Pads, Magnaflow Magnapacks 4", SE Front Fascia
    Check Out My Car! ---
  17. #17 Re: stock 04 grand prix GTP
    GTP Level Member chevyy1212's Avatar
    Oct 2008
    IL
    Quote Originally Posted by TheAce144 View Post
    No Grand Prixs in 09.. Just sayin
  18. #18 Re: stock 04 grand prix GTP
    All I know is that the 97-03 GTP running on a 3.4" pulley has the same amount of boost as the 04-07 GTP with a stock pulley, which is 3.8"...maybe around 8-9 lbs?
    fixed it for ya
    and no, they produce just about the same boost on the stock pulley.
    putting a 3.4 on the gen 3 without anything else(supporting mods) would make it produce prolly up to 10-13psi over the stock psi of 5-7. The smaller pulley makes the SC spin way faster than before, so it makes more boost.
  19. #19 Re: stock 04 grand prix GTP
    Dec 2010
    Montreal, Canada
    fixed it for ya
    I don't know, got the info from Will @ Overkill...said that the genV supercharger was more efficient than the previous generation and therefore made more boost...here is the mail he sent me :
    "If you don't have a downpipe, I would start there first, and then drop the pulley size. You'll probably find you can only drop to a 3.6" pulley size, best to get a modular pulley system so you can swap sizes easily if needed. Remember that 04+ with the GenV superchargers are much more efficient, so when you see a pre-gen running a 3.4" pulley, you have nearly that equivalent boost with a stock pulley."
  20. #20 Re: stock 04 grand prix GTP
    Calculations?
    Quite a bit.
    Considering the GenV makes as much power as a GenIII with a 3.4" slapped on it whilst the GenV is still on a stock or close to stock pulley...there is no ramp up on the GenV...the rotors are better...and coated better for that matter...its also a little bit bigger of a blower as well...so since it is displacing more air, its of course going to make more power...and it can do it without pulling as much power FROM the motor to make it...unlike the GenIII...which needs hogging out...re-coated rotors, the entire inlet ramp smoothed so the air ramp up isn't all screwed like it is from the factory...and the outlet opened up quite a bit...its just a increase in technology really IMO.
    Better overall design...but it is still a heaton...and the more you pulley down, the more heat it makes and the more power it is going to TAKE FROM THE MOTOR to make more power.
    I always had a nice little scale like this...
    Both blowers will make about the same figures from the factory...while the GenV car will still make about 10-20 more horse and torque to the wheels than the GenIII car if they are tossed side by side with the same pulley.
    3.8" GenV = 3.5"/3.4" GenIII
    3.4" GenV = 3.2" area GenIII
    3.2"/3.0" GenV = 2.8"/2.55" GenIII
    That's how I always understood it...Steigmeier Performance...who is VERY well known for porting the M112 cases for the 03-04 Cobra's did a GenV M90 and said they gained nearly 20 crank horse from just their porting...I never saw any actual dyno charts...just their claims...but it was ported in a rain drop or tear shaped outlet...just like they do on the M112...something strange like this...
    I'm just gonna quote this from my other thread to help you out in understanding the GenV to GenIII...and how the pulley size compares.
  1. 2005 Grand Prix Stock stereo
    By mpoynter31 in forum Audio, Security & Visual Electronics
    Last Post: 05-23-2010, 10:37 AM
  2. does grand prix has poor stock headlights or is it me?
    By raymondtrudeau in forum General Tech Discussion
    Last Post: 10-20-2009, 06:25 PM
  3. Weight of Stock Wheels for the Grand Prix
    By Quicklynx in forum Tires & Wheels
    Last Post: 07-16-2009, 02:06 PM
  4. 2001 stock grand prix gt
    By grandprixgt in forum General Tech Discussion
    Last Post: 06-18-2009, 11:32 AM
