Thread: 4.7PSI of Boost with 3.4 Set up
Results 1 to 20 of 38
  1. #1 4.7PSI of Boost with 3.4 Set up
    Largo, Florida, United States
    got my Aeroforce the other day and it shows 4.7PST at WOT
    the 3.4 set up is supposed to get alot more then that I replaced my all my Vac lines, all new Gaskets
    Didnt find a vac leak what else could it be?
  2. #2 Re: 4.7PSI of Boost with 3.4 Set up
    GTP Level Member
    Nov 2008
    MA
    boost bypass valve?
    03 GTP - 13.8 @ 100 2.160ft
    99 GTP - DD
    *Operation Iraqi Freedom/Operation New Dawn Veteran*
  3. #3 Re: 4.7PSI of Boost with 3.4 Set up
    Norristown, PA
    You shouldn't be getting ALOT more psi, but I agree you should be getting more.
  4. #4 Re: 4.7PSI of Boost with 3.4 Set up
    isnt like 9-10PSI normal with a Similar setup to mine?
    3.4
    DHP PCM
    Full exhaust
    Headers
    MSD ignition
    MSD Wires
    AL 104's
    4'K&N with Wizaired CAI
    Ported Supercharged
    Ported Throttle Body
  5. #5 Re: 4.7PSI of Boost with 3.4 Set up
    9-10 is about right but BBV or vac leak. go, have fun.
  6. #6 Re: 4.7PSI of Boost with 3.4 Set up
    Nov 2009
    Grand haven
    THIS^^^^
  7. #7 Re: 4.7PSI of Boost with 3.4 Set up
    Outer Space
    Quote Originally Posted by shawngtp View Post
    THIS^^^^
    x2 that. ...and fuel trims at +16.4 would indicate vac leak.
    02 GTP 13.6 @ 100mph - SOLD
  8. #8 Re: 4.7PSI of Boost with 3.4 Set up
    figured as much bbv
  9. #9 Re: 4.7PSI of Boost with 3.4 Set up
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    It would have to be a HUGE vac leak. Its a the BBV
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  10. #10 Re: 4.7PSI of Boost with 3.4 Set up
    Quote Originally Posted by 01gpgt01 View Post
    Good call on the BBV after he said it was the BBV
  11. #11 Re: 4.7PSI of Boost with 3.4 Set up
    aside from stealership is there a place i can buy it?
    Autozone says they dont sell em
  12. #12 Re: 4.7PSI of Boost with 3.4 Set up
    Hagerstown,Md
    Ed morad im sure has some.
  13. #13 Re: 4.7PSI of Boost with 3.4 Set up
    Hagerstown,Md
    I was pointing out it probably was not a vac leak as mentioned. Good job posting useless crap though
  14. #14 Re: 4.7PSI of Boost with 3.4 Set up
    Florida
    I think it might be a BBV.....
    I'd check Ed Morad first, if he doesn't have one he could probably get one for you in a short time. Other than that, you might try a junkyard where you got all your badges from, just be cautious....
  15. #15 Re: 4.7PSI of Boost with 3.4 Set up
    Banned - Busted For Scamming
    Feb 2009
    Just bring it over and ill fix it. It is not the bbv, i checked its operation when i put it back on.
  16. #16 Re: 4.7PSI of Boost with 3.4 Set up
    No problem, glad I could help!
  17. #17 Re: 4.7PSI of Boost with 3.4 Set up
    then what is it? if not the BBV
  18. #18 Re: 4.7PSI of Boost with 3.4 Set up
    Feb 2009
    Thats why you need to bring it over so i can look at it. Im not going to play guessing games.
  19. #19 Re: 4.7PSI of Boost with 3.4 Set up
    You should...those are fun.
  20. #20 Re: 4.7PSI of Boost with 3.4 Set up
    Jan 1970
    Maquoketa, Iowa
    My guess is it will take at least 6 beers to fix it. Better just grab him a case.
  1. Why is my boost gauge only reading vacuum and no boost?
    By gtp02 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-21-2010, 02:26 PM
  2. dic boost gauge only shows half boost
    By SilvaMan61 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-10-2010, 07:40 PM
  3. no boost!!
    By jaygtp98 in forum General Tech Discussion
    Last Post: 04-15-2010, 01:12 PM
  4. curious if going past 14.7psi....
    By fst in forum Turbo
    Last Post: 09-15-2009, 11:51 AM
  5. How much boost?
    By Bigbm80 in forum General Tech Discussion
    Last Post: 07-09-2009, 04:01 PM
