Thread: injectors yet?
Results 1 to 9 of 9
  1. #1 injectors yet?
    SE Level Member RICE KILLER's Avatar
    st. paul mn
    so i am running an xp cam with all the goodies, fwi, headers with a 3.4 and all the other basic sporting mods. i plan on doing either a N* TB or a ported stock TB, ported SC, and ported/polished LIM and hopefully drop to a 3.2 with a tune. so heres my question can i run the stock injectors or should i upgrade?
  2. #2 Re: injectors yet?
    Apr 2009
    stockton ca
    stock injectors down to 3.2 then you would need injectors
  3. #3 Re: injectors yet?
    I ran stockers on a 3.1" and only went static when the 3.0" went on there...might have got lucky though.
  4. #4 Re: injectors yet?
    st. paul mn
    also another Question for my set up would a stock ported TB be ok or should i go with a N*
  5. #5 Re: injectors yet?
    Charles City, IA
    ported stock is ok.
    SMGPFC Two Nipple General
  6. #6 Re: injectors yet?
    Jan 1970
    Maquoketa, Iowa
    Depends on how you tune it or how the car breathes, but I would just go ahead and look for some. Its better to have the extra headroom than to be worrying about it after you go static. Also, when you tune it, it could be close to static that day and the weather may change the next and you could go static again without even knowing. When the injectors go static, you go lean.
  7. #7 Re: injectors yet?
    Donating Users kfish's Avatar
    Ohio
    my 33's were on the verge of going static at a 3.5" but that was on a top swapped car if that makes any difference.
  8. #8 Re: injectors yet?
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    Quote Originally Posted by kfish View Post
    Yep mine are hitting 95 percent IDC on hot days. In the winter mine will probably go static(on a 3.5 also)
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  9. #9 Re: injectors yet?
    You can snag a set of 42.5'ers off of mustang/lightning forums...the green tops for cheap when they demod just a FYI
  1. How are the 42# injectors?
    By $03gp/gt$ in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-21-2010, 08:00 PM
  2. 42.5# injectors?
    By fst in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-06-2008, 02:17 PM
