Re: 4.7PSI of Boost with 3.4 Set up
FoSHO99
My guess is it will take at least 6 CASES to fix it. Better just grab him a case.
:th_thumbsup-wink:
After installing my Aeroforce, it was showing less boost than the factory boost gauge. I had to set the altitude in my Aeroforce before it was accurate. You probably already did that...but just in case you didn't, you may want to do that.
That only changes your HP and torque readings on the aeroforce.
Boost is read from the PCM which reads from the MAP sensor. Can't really change that.
i bought a BBV solnoid today
installing it tommorrow!
minichopper6hp
Just bring it over and ill fix it. It is not the bbv, i checked its operation when i put it back on.
Spartangl
:confused:
gtpinsc
:confused:
he lives in orlando. Thats like 2 hours North and i was JUST there Saturday!
Lazy bastard, i made that drive regularly every weekend for a long time.
hell id drive 2 hours if someone offered to help. instead of just buying parts that u think may be the problem.... to each their own. hope ya get it fixed.
gtpinsc
No kidding.
I wish there were people like that around my area. Oh wait.
LOLz
well 99% of the people in this thread thought it was the BBV Solnoid, and before that when i felt it not getting the boost they thought it was a Vac line.
Ill see what i can do about making a trip up there soon Logan, When are you free?
Also replaced my BBV Solnoid (DEF NOT THE FIX)
Spartangl
99% of the ppl also werent under your hood working on it recently. he said he checked BBV and it was fine. :th_winking:
If it's not the solenoid, it could be the electrical going to it. I can't believe nobody suggested a simple test first.
There's a vac line going from the solenoid to the actuator. Remove this line from the actuator and plug the line leaving the port on the actuator open. If you see full boost, the solenoid is what's messing you up.
scimmia, i walked him through that 2 weeks ago, was not the problem. I have no idea why he hooked it back up. Anyways, am free most days before 5 pm, just call and see if im busy.
And yet he replaced the solenoid? WTF???
Scimmia
Right. That makes sense.
mini wasnt under my hood lol
I brought the Supercharger to him to powdercoat Nothing was hooked up
and i replaced the Solenoid to Eliminate anychance of that being the problem.
