Thread: KR issue, need help
Results 1 to 11 of 11
  1. #1 KR issue, need help
    Donating Users ninnyGTP's Avatar
    Nov 2008
    Moreno Valley, California
    Alright, so I've been having a decent amount of knock and I can't seem to figure out why. For my mods, it just doesn't make sense.
    First things first, mods are as follows, L32 engine, n* TB, SSAC headers, 3" high flow, 2.5" catback, 1.9 modified rockers, 180* t-stat, 104 plugs gapped at .050. 3.6 MPS
    See about 2* of knock at the top of first and 2nd it's about 6* at about 3500+. It's not false as i've taken the belt off as well as dropping the timing to 10* and it goes away. I've tried replacing plugs, changing the gap, going colder t-stat (car never gets hotter than 170*). It just doesn't make sense to be knocking that much on 8psi.... Now I do have an exhaust leak at the rear crossover just cause the band clamp isn't sealing like it should so I can't tell you my correct AFR. But the PCM is commanding 11.7 and my wideband reads anywhere from 10.8 to 11.2. Anyone have a sollution, or better yet, anyone local willing to try and help me out?
    98 Grand Prix GTP L32, GenV, n*, 3.2", 1.9 rr's, 3.29 gears. All that jazz SOLD
    99 Mustang GT Steeda UDPs, 3.73s, Pypes O/R xpipe, Accufab plenum, Steeda CAI, B&M ripper, MHS s2 cams, 10.5:1 compression (290whp/310wtq) SOLD
    01 SVT Cobra #3654, B&M Ripper, K&N FIPK2, MAC O/R xpipe
  2. #2 Re: KR issue, need help
    stock front sway bar?
    Who tuned it? If KR is going up, it must be leaning out unless something else is wrong.
  3. #3 Re: KR issue, need help
    Outer Space
    MAF tuned correctly?
    02 GTP 13.6 @ 100mph - SOLD
  4. #4 Re: KR issue, need help
    An exhaust leak with throw your o2's off...and that could be your issue.
  5. #5 Re: KR issue, need help
    Nov 2008
    The MAF is still on a box ZZP LQ4 tune. I'm gunna fix the exhaust leak tomorrow and see what happens.
  6. #6 Re: KR issue, need help
    Outer Space
    Any box tune needs to be tuned further... because your trims vary according to weather. I had my car tuned for winter... now I am MAF tuning it again... to get my summer tune straight.
  7. #7 Re: KR issue, need help
    Nov 2008
    Well I'll see what I can work out.. I wasn't sure if the heat of CA would be a variable seeing is all the vendors are on the east coast and I know they don't see 95+ weather like I am now haha.
  8. #8 Re: KR issue, need help
    Nov 2008
    Alright, update. Wrapped my intake with insolation wrap, changed my plugs to 103's with a .050 gap. Then I fixed my exhaust leak. Turns out if was actually comeing from my EGR port that I blocked off. Took it for a spin and now i'm only seeing 3* of KR.. Could this just be pre-ignition from too low of a gap?
  9. #9 Re: KR issue, need help
    Could be...try gapping them a tad more at like .055" IMO
  10. #10 Re: KR issue, need help
    Nov 2008
    I'll give it a shot in tha AM... Now, time for sleep haha
  11. #11 Re: KR issue, need help
    GT Level Member jdmgtp's Avatar
    MI
    Quote Originally Posted by ninnyGTP View Post
    Probably not.
  1. Need Help Car issue
    By redrunner in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-13-2010, 09:00 AM
  2. MAF Issue
    By prostallion347 in forum General Tech Discussion
    Last Post: 03-30-2010, 11:36 AM
  3. Please Help!!! AC Issue
    By sb76 in forum General Tech Discussion
    Last Post: 07-22-2009, 03:03 PM
  4. GTP pcm issue with ZZP
    By Regalgs98 in forum PCM Tuning
    Last Post: 02-18-2009, 02:16 AM
  5. I have a big issue please help me
    By Goany in forum General Tech Discussion
    Last Post: 12-02-2008, 02:51 PM
