Thread: Car is slow now what to do what to do
Results 1 to 20 of 21
  1. #1 Car is slow now what to do what to do
    Feb 2010
    Flint Michigan
    Well today I changed my wheel hub bearings because they were grinding. Also I changed my water pump because it was leaking water from the little holes in it. Car did not over heat just to add. Also did a tune up new duralast wires and autolite 605. I took out acdelco iridium plugs.
    My problem is the car runs slow now went taking off the low traction light comes on and slows car down but even with the traction thing off it still does not launch hard or spin the tires.
    Also while driving it does not pull as hard.
    This is on a stock 1998 gtp with fwi.
    What should I do or look for need help getting ready to put my old stuff back on. Why would this happen and I know it's not all in my head.
    Also when I take of hard it wants to instantly shift into second
    also the car cranks more before starting so it harder to start now
    and my altenator has a high pitch squeal what does this mean
    A little upset spent time and mney to better my car and seem to have made it worse
    any help would be great thanks alot
    I'm thinking about unpluging my wheel hub bearing so the abs light will be on then see how it drives
  2. #2 Re: Car is slow now what to do what to do
    Feb 2010
    Flint Michigan
    Any help could it be the colder plugs on a stock motor
  3. #3 Re: Car is slow now what to do what to do
    GTX Level Member Biohazed's Avatar
    Philadelphia, Pennsylvania, United States
    plugs may be too cold for the car, also is the serp belt routed correctly?
    *image too tall*
    BMR F + R Strut Bars - Falken Torque V 18's - JVC S900 - Kicker C10's - Spyder Projectors, Wizaird,
  4. #4 Re: Car is slow now what to do what to do
    GTX Level Member Rather B Blown's Avatar
    Dec 2008
    London, Ontario
    make sure your plug wires arent crossed
    Quote Originally Posted by Reptile
    It sounds like you accidentally stuffed a midget in the downpipe, and he's hammering out an SOS to get out.
  5. #5 Re: Car is slow now what to do what to do
    Pennsylvania
    It doesn't sound to me like you've got a KR problem to be fixing with colder plugs. Put in some 606's and see how it goes - it's a $12 fix.
  6. #6 Re: Car is slow now what to do what to do
    GT Level Member hourang's Avatar
    commerce, mi
    also be careful with those duralast wires, i put some in my camaro and spent forever trying to diagnose why it ran like crap with nitrous on only to find it was the crappy $90 duralast wires. put $50 msd wires in and it ran like a raped ape.
    -Jeff
    98 GTP Black 4dr - fully loaded - short ram intake, tinted tails, hole in resonator.
    sold 98 camaro ss - 6spd fully loaded - cam, intake, exhaust, ford 9in rear 4.11s, 6point chromoly cage, tnt 150shot nitrous, nittos, etc.
  7. #7 Re: Car is slow now what to do what to do
    Meh...for what they are they are great on the 3800...Lifetime warranty FTW
  8. #8 Re: Car is slow now what to do what to do
    Feb 2010
    Flint Michigan
    i got it to run better the coil was messed up but now it still got a miss fire only when i launch hard it only one miss fire at 4500 rpms why would it do that maybe i should but in stock plugs and see what happens because its a stock motor with colder plugs i dont think i need it
  9. #9 Re: Car is slow now what to do what to do
    Well if you would have actually read the safely modding thread a typed up and not just said you did...then you would know what correct plug size to run and what would be good for your setup, etc.
  10. #10 Re: Car is slow now what to do what to do
    Feb 2010
    Flint Michigan
    Oh ya I did read that you should reread it because it says 606/605 stock engine
    Cooler the Spark Plugs, the lower your KR, but keep in mind, too cool of a plug will not always help you. 605/606’s are for a stock car, TR55/104’s are for small bolt-ons or basic 3.4” setups, TR6’s are for 3.25” Pulley range (Rockers, IC, etc.) and Autolite 103 Copper Core Race Plugs are for the extreme application 3.0” Pulley and smaller. Cost: $10-$20 appox.
    So do your info before you post it and get mad when someone uses it
  11. #11 Re: Car is slow now what to do what to do
    Are you kidding me? Your engine is stock. You need stock temp range plugs. Is it that hard to understand? Apparently you do need to go back to V8 cars because this boost thing is too much for your mind to handle. I would just like to know what you don't understand in my spark plug temperature range application...please explain to me how I didn't word it or understand it right.
  12. #12 Re: Car is slow now what to do what to do
    Feb 2010
    Flint Michigan
    605/606’s are for a stock car says it all fix your post thank you
    i have a stock motor and you say 605 are for stock cars thank you for your posts
  13. #13 Re: Car is slow now what to do what to do
    I still don't even get what your trying to argue with me about. Its whatever...your sentences make no sense anyways. Punctuation helps a ton. Let me make it even clearer for you.
    If you have NO MODS: Autolite 606 or AC-DELCO replacements...or whatever else retarded plug you want to buy to toss in there.
    Small Bolt-Ons Stock Pulley Size: Autolite 605's.
    3.4" Setup and other supporting Mods: Autolite 104 Copper Plugs or NGK TR55's.
    Smaller than a 3.4" Pulley yet not going under a 3.0": NGK TR6's.
    Smaller than a 3.0" Pulley and for extreme builds: Autolite 103's.
    So...since it is that hard to understand, I extended it even more. I went over my information and I see it as correct. But please, feel free to post the correct information below...since you know more and I'm wrong.
    Thanks
  14. #14 Re: Car is slow now what to do what to do
    Feb 2010
    Flint Michigan
    STOCK=NO BOLT ONS, ITS STOCK
    but thanks car runs fine with 605s now coil was bad thanks for being such a super uber cool guy with the posts
    let it go grow up
  15. #15 Re: Car is slow now what to do what to do
    GT Level Member torq455's Avatar
    Dec 2008
    Alabama
    2002 GTP: K&N, 3.2 pulley, flipped mounts. ZZP SS headers, 180 stat, NGK TR6's, MSD wires, Reptile ported TB, ported S/C, ported LIM, Intense Stage II heads with larger Manley severe duty SS valves, Yella Terra 1.9 full roller rockers, LS6 springs, Racetronix fuel pump re-wire, Oil pressure "kit", JMB FWI. Mustang dynoed at 240 WHP, 272 WTQ.
  16. #16 Re: Car is slow now what to do what to do
    Feb 2010
    Flint Michigan
    am i right or am i right they may not be what he ment to say, but thats how he said it.
  17. #17 Re: Car is slow now what to do what to do
    Jesus christ. Sorry your 606 to 605 plug is going to make a **** TON of difference. I just use it as a reference guide for basic modding. Do whatever you want...its your car.
  18. #18 Re: Car is slow now what to do what to do
    Feb 2010
    Flint Michigan
    Thanks alot let it go man
    you made a mistake it fine we all do
  19. #19 Re: Car is slow now what to do what to do
    Topeka, KS
    Hmm sounds like i need to drop down to TR6's. Maybe that will help with some of my knock.
  20. #20 Re: Car is slow now what to do what to do
    Quote Originally Posted by monsterjam5000 View Post
    Hardly.
    Next contestant.
  1. slow shift
    By buddha in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-13-2009, 09:37 PM
  2. holy slow
    By pontiac88 in forum Off Topic Discussion
    Last Post: 10-20-2009, 04:28 PM
  3. why does my car die when i slow down? I need help!
    By joeyG97 in forum General Tech Discussion
    Last Post: 05-20-2009, 01:22 PM
  4. Does my car seem slow?
    By Toofastgs in forum Off Topic Discussion
    Last Post: 04-18-2009, 07:28 PM
  5. slow
    By Toasty in forum Off Topic Discussion
    Last Post: 02-12-2008, 07:03 PM
